Author Topic: Improve Scrollbars  (Read 18371 times)
  - i appreciate it wont be obvious why the scrollbars need to be a bit narrower for the lowlight behavior to take effect but its so some skins are not affected by the change
A positive side effect of this is that this currently gives touchscreen users the option to disable any 'hidden' scrollbars.
For the near future you might need to consider having an overrule button in the main preferences panel: "optimize the interface for touchscreen".
i've made the following two changes for the next update:
- new setting "ScrollPanelMargin" which reduces the entire width of the skinned scrollbar (this differs from "ScrollBarMargin" which narrows the slider but the scrollbar itself stays the same width of 17px). The value is capped at 10
It's not very important, but I noticed that if a gradient is set for the scrollbar, that gradient is gone when an adjustment to the width is made.
- mouse over now has the same colouring behavior as gripping the slider.
Thanks for this change! But this still leaves the problem unsolved of "finding" slider in the first place because it only changes the color when the mouse is over slider, not scrollbar.
Can't you make it change the color when the mouse is over the (invisible) vertical line of scollbar like this image?
  • MB Version: 3.6.9255 P
and scrollbar background
<element id="ScrollbarNoArrows">true</element>
<element id="ScrollPanelMargin">1</element>
<element id="ScrollBarMargin">2</element>
but they show up again when narrow scrollbars is chosen.
also, scrollbars are not going narrow when Preferences option changed
on the positive, the scrollbar margin now only shows with narrow scrollbars, allowing a high contrast border as per one of my suggestions.  Thank you :)
you need to restart. MB prompts you to do so - did you?
Certainly did.  Even tried several skins to check if it was something in the skin I was testing.
But even MusicBee3 wont go to narrow scrollbars
EDIT:
BTW version 3.0.5902.38085
Last Edit: February 28, 2016, 09:21:50 PM by Bee-liever
Its fixed now
yes, the scroll bars are narrow
but unfortunately, the border attribute no longer shows on mouse over :(
ver:3.0.5902.38378
scrollbar slider border definitely not showing on mouse-over
images removed - see reply #27 below
<element id="Panel.ScrollBar.Default" bg="246,245,243" bg2="219,196,191" bdr="234,144,134" />
    <element id="Panel.ScrollBar.Lowlight" bg="195,185,172" bg2="178,165,149" />
    <element id="Panel.ScrollBarBackground.Default" bg="228,203,200" bg2="206,191,181"/>
Last Edit: February 28, 2016, 11:09:05 PM by Bee-liever
I have changed it so it doesnt do that if the scrollbars are narrowed by the skin config. The gradient still gets removed when the user chooses narrow scrollbars.
works fine for me. The only suggestion i have is the obvious - perhaps you have set it to another value further down
vers:3.0.5902.39628
works fine for me.
My apologies. It is working but I wouldn't say it was fine.
The border colour is being dimmed when applied to the narrow scrollbar slider.
Using 255,0,0 for a default border shows as 238,165,163 when narrow.
This only further exacerbates the need to barstardise the default colours to get a good contrast for narrow scrollbars.
I think I will remove the ScrollBar.Lowlight elements from my skins and not bother with it in the present form. :(
The gradient is back for the slider, but not for the background.
i will correct that for the next update
the reason it was done is because of some skins the gradient becomes extreme due to the narrowness of the panel and slider. I want to leave that behavior as a default but i am willing to add a boolean override to MB just uses the exact colours as specified in your skin to the user-set narrow scrollbar (i appreciate having to do that is a bit tail wagging the dog but i want to get the best overall behavior for a wide range of skins)
