Author Topic: Highlight rule Sample Rate seems not to work  (Read 1572 times)
Novatlan
I tried creating a highlight rule in Prefs - Tags (2) "Sample Rate is greater than 95" to colour all tracks who have a sample rate of 96kHz or higher.
But MB3 colours _all_ tracks, even if they are 44.1 or 48kHz.
Is this a bug or is there something special I need to set?
Last Edit: January 28, 2016, 05:20:30 PM by Novatlan
Novatlan
That works, awesome!
Sorry - I did not think of that because the properties window shows it as kHz.
I assume it is the same with the bit rate?
vincent kars
Sample rate is displayed in kHz
Rule should be in HZ hence
Sample Rate > 95000
will do the job
