Author Topic: Mini Player Now Playing Assistant Doesn't Use Ignore Rules  (Read 1600 times)
Pingaware
As stated on the tin. The now playing assistant accessed from the mini player seems to not use the 'Ignore Words' list under Preferences>Tags (2).
Using 3.0.5864
in all the cases i checked its working ok, so can you post a screenshot
