Hey folks, got a question - I use MusicBee primarily in the Compact Player mode, and it's bugged me for a while that it seemed like there wasn't an option within the repeat toggle to repeat the song you're on until you toggle it to a different setting, and I've gotten by via using the queue feature until now. I was doing some searching and found there is a Repeat One option, but from what I can tell, it's only available if you have the player control buttons set as a popup in the Compact Player, not while the controls are all displayed.
Is this intentional? Is it hidden somewhere else that I haven't been able to find? I'll switch to popup controls if I absolutely have to, but it'd be so much handier for it to be a third toggle on the Repeat button.
