But bee-liever mentioned exactly that one before, and you responded (post #4) that it didn't work.
I couldn't believe that. It probably didn't work then because you had changed some other stuff too while experimenting.
I think what I did was change the override to 255,255,255 and it didn't work. It never occurred to me to comment it out.
Btw I really like the way your skin is developing.
Despite the alternating color bars, eh? :-)
Thanks very much.
If you haven't looked at the "no cover artwork" graphic, you should.
I'd like to say I'm done with it now, but as I'm sure you know, there's always something else popping up that needs a tweak.
