Author Topic: Zen Hive  (Read 51418 times)
Yep, the now playing panel overlaps that border line.
it's up to Steven if he feels like changing that.
Understood. I assume it's an oversight since that line exists top to bottom on the left side of the main and playing tracks panels.
phred, could you send me your settings file?
PM sent
Skin is updated with some minor tweaks and additions.
Please add a screenshot(s) to your original post to wet our appetites
Done that.
fossii
Great skin - i like it very much - Thank you.
Do you have an idea why the text in my player panel is red and not yellow (as in your snapshots)
Thanks
That's weird.
Are you using Windows 10 ? (as I am)
That same text is red in mine also.  FWIW, it appears that fossii and I have the progress bar info on top and you (hiccup) have it on the bottom. I'm using Windows 7
The red text should be fixed. (re-uploaded)
Could you post a screenshot of how he progress bar looks in Windows 7?
fossii
I recently changed the bar from top to bottom, text is red in both versions.
I am using Win 10. strange...
And you are using the updated version that I uploaded a couple of minutes ago?
Could you make a color-accurate (png) screenshot of the 'red'? It would help if I know the exact RGB value of it.
fossii
sorry for the circumstances.
I have changed the skin to the default theme, and changed again to  the 1st and the 2nd version of your skin.
Now the text appears in yellow in both versions!
Didn't get it why, but now the skin is perfect to me :-)
Great.
Thnx for reporting and the feedback.
Just downloaded the latest update and red is still red.
According to Instant Color Picker the red is 184,44,8
I'll PM you a link to the PNG screenshot
Thnx phred. That was an oversight of me.
The reds should now really be gone.
About the progress bar and track times not being centered perfectly:
I had to break a few skinning rules to accomplish what I wanted with this skin.
Under Windows 10 it now seems to turn out well and exactly as I intended.
But it just won't work under MusicBee v2.x, and now it seems it also won't be perfect under Windows 7.
I am afraid there's not much I can do about that.
Last Edit: January 04, 2016, 08:16:03 AM by hiccup
Looking at your screenshot again, the slight mis-alignement could also be due to you using a non-default main font for MusicBee?
Fixed! Red is now yellow.
I don't think I'm the one who mentioned this as I hadn't even noticed it until you just pointed it out.
And, it may indeed be due to my font selection.  I'll have more time to check that out later today.
