Author Topic: Library Explorer Element  (Read 6159 times)
What element controls the fg and bg of the FIND button in the Library Explorer?
its derived from Controls.Button.Default
let me know if you need an override
I have changed the bg and fg in Controls.Button.Default and I see no change in the Find button.  Just to be certain we're talking about the same thing, here is a screen shot:
I'm trying to get the Find button to look like the Podcast count button.
Not truly knowing what I'm doing with skin modifications, would an override be the answer?
Somewhat related - hiccup mentioned to me that he couldn't see a Find button for the LE and wondered if it was user-enabled.  Neither he nor I are able to see where it might be an option to enable/disable it.  And in 2.5, once the Library Explorer is enabled, I have to double-click the LE header to get the search field and Find button to show.  In 3.0 it shows as soon as it is enabled.  This is all taking place in the left panel.
Not a biggie, but a bit strange indeed. When I double-click the LE header, the LE panel just expands to the top of the window, covering the whole left panel. (v2.5)
It shows up when you choose "search" from the menu or when you start typing in Library Explorer
That's the intended behavior.
Last Edit: December 05, 2015, 09:14:46 PM by psychoadept
That's funny, that is the first time ever that that 'find' option shows itself there.
Clicking 'search' in the menu didn't do the trick, but starting typing there indeed made it reveal it's presence.
Well, at least we've got that problem resolved.
But I'd still like to know what element needs to be changed in order to change the color.  The one Steven said was it isn't changing anything.
Last Edit: December 05, 2015, 11:54:12 PM by phred
  • MB Version: 3.6.9318P
@ phred, you will need an override to achieve what you want.
As Steven said, it's derived from that elements colours, but they're blended with the LH panel colours to give a more subtle effect.
Good explanation, Bee-liever.  Thanks.
@Steven - I'll take you up on your offer to provide an override for Controls.Button.Default so I can manipulate the Find button in the Library Explorer.  Thanks.
i have added for the next update:
Controls.FindButton.Default
keep in mind it also is used when searching the Playing Tracks panel
its uploaded now
Last Edit: December 06, 2015, 12:58:00 PM by Steven
Great!  Working as expected in v3
