Quote from: hiccup on January 03, 2017, 07:51:20 PM Ah, o.k. AvikB's response in 10, 9, 8, 7,... (just kidding, he's fast, but not that fast ;-)
Quote from: AvikB on January 03, 2017, 07:52:58 PM Damn! He is that quick!
Aha, now I also know who the hidden user is ;-)
yes you are right, right now it does not do anything. i added it as a visual indicator for search. I will make it clickable in next update.
Very minor issue, the text in this bar (This section allows you to view...) is a bit hard to read in Dark theme.
Also minor: Sometimes a scroll bar will appear, while there is no text below the pane to actually scroll through. Also, it doesn't have Dark theme coloring.
Thnx, I'll try to remember it's a system/browser issue and not bring it up again... It was just weird to see it often seems to appear with short postings, while you would expect them with longer postings. I thought some forum code might be responsible for triggering it.
@AvikB - I want to update the readme on one of my skins, but I don't see any way to edit an existing submission. If it already exists, please point me to it.If it doesn't, I think a vehicle for editing/updating all all-ons is needed.Thanks.
