Author Topic: [WEBSITE v2] MusicBee website and forum redesign  (Read 647639 times)
AvikB
Aha, now I also know who the hidden user is ;-)
haha. I turned off my status yesterday during some tests on the forum profile. But i mostly get email notification on my email client and then visit this thread, not always active on the site.
yes you are right, right now it does not do anything. i added it as a visual indicator for search. I will make it clickable in next update.
Great! Thanks.
Very minor issue, the text in this bar (This section allows you to view...) is a bit hard to read in Dark theme.
Also minor:
Sometimes a scroll bar will appear, while there is no text below the pane to actually scroll through.
Also, it doesn't have Dark theme coloring.
AvikB
Fixed for next update.
Also minor: Sometimes a scroll bar will appear, while there is no text below the pane to actually scroll through. Also, it doesn't have Dark theme coloring.
That is controlled by the system and the browser itself. I will not change it, in the past i have used custom scrollbar and they don't behave nicely with different browser. Some browser even don't allow you to change it without any sort of javascript hack(firefox for example).
Thnx, I'll try to remember it's a system/browser issue and not bring it up again...
It was just weird to see it often seems to appear with short postings, while you would expect them with longer postings.
I thought some forum code might be responsible for triggering it.
AvikB
Thnx, I'll try to remember it's a system/browser issue and not bring it up again... It was just weird to see it often seems to appear with short postings, while you would expect them with longer postings. I thought some forum code might be responsible for triggering it.
You are right. There is a small glitch there. It is a easy fix, somehow missed it. :S will be fixed.
@AvikB - I want to update the readme on one of my skins, but I don't see any way to edit an existing submission.
If it already exists, please point me to it.
If it doesn't, I think a vehicle for editing/updating all all-ons is needed.
Thanks.
  • MB Version: 3.6.9255 P
Thanks.
@ phred
Open Dashboard ==> view all add-ons
in the "Your published add-ons" panel there is a little pencil symbol on a blue tile
you can edit the original post there
AvikB
New message icon for the next update:
and new message:
This should make it much more clear than before. Hope this will clear any confusion we had regarding bell icon.
CritterMan
  • Now with FiiO M11!
Looks nice!
