Author Topic: [WEBSITE v2] MusicBee website and forum redesign  (Read 560647 times)
btw i have question for you since you are a mod in the current forum.
In the current forum you can see a user's ip address and ip-block him, which i removed in the new forum since ip-address blocking is not accurate and can cause issues for others.
Do you actually use it? if so i might add it otherwise i will leave it as it is.
i used to block by ip address but as you suggest it can cause issues because spammers use hijacked pc's these days. Saying that, i would still want the ability to do that if i needed to
AvikB
Do you use it from the posts view or as phred says from mod panel?
I am decided on that structure, the wording can be improved.
Can you say what wordings you are not sure about?
Yes it is pretty simple, a bit time consuming though, since moving, renaming, adding description.
No programming is required. you will need admin rank to do so btw. Ask steven he should be able to make you admin in the test forum.
I'm willing and able to do that. But I would like it if we are (for 99%) agreed on the structure and naming before I do that.
Also, I am curious about this:
Since there are some discrepancies in the structure and boards between the old and new forum, simply exporting all existing boards and topics will probably not be possible.
Should we design some simple diagram where we can see where old topics and boards should go in the new forum structure?
AvikB
Speaking for myself as a moderator, I typically don't block someone via the IP because as you say, it might cause issues for others.  But there have been a couple of times where I have blocked the user's IP.  But this is always done from the 'ban user' option and not from within an offending post.  As long as the IP logging remains somewhere, I don't think there's a need to have the option show in the post.  Hiccup and/or Steven may feel otherwise and I would default to whatever Steven says.
I have only removed from posts view, it is still available in the forum moderator/admin panel.
AvikB
from the admin panel
Ok, thats fine, i won't add back in post view then.
"report to moderator", "quick edit" is still available though.
To refresh our minds, this is where I believe we left off some three months ago:
ANNOUNCEMENT
MusicBee Release               information on the latest official release version
MusicBee Pre-Release         the latest 'nightly' and pre-release versions
GENERAL
Tips and Tricks
General Discussions            Child boards: Discussing MusicBee, Polls
MusicBee Wishlist
MUSICBEE ADDONS
Customisations                  Child boards: TheaterMode, Skins, Icons, Visualisers, Localisation, Showcase
Plugins
SUPPORT
Questions                         Child boards: Questions on MusicBee, Support in non-English languages only
Bug Reports
Developers                       Child boards: MusicBee API, Skins, TheaterMode
BEYOND MUSICBEE          Child boards:Related Interests, Rubbish Bin
Edit,
If there is not much enthusiasm about a foreign language board (it was only a suggestion from me I don't care about very strongly), support would just be be:
SUPPORT
Questions
Bug Reports
AvikB
I am talking about board descriptions, since you haven't proposed any description for most boards here:
http://getmusicbee.com/forum/index.php?topic=16894.msg99771#msg99771
we need to get descriptions for boards and then changing it by other member's feedback as needed.
We seemed to resolve this a long time ago. The naming structure is fine :)
that would be a good idea.
The structure is not too different, the only problem would be question board, since currently all questions are in general we need to rename general into questions, and move the sticky thread to general. others should be easy, since they require just renaming and moving.
I wasn't aware I was holding things up ;-)
Ok, here are some further proposals:
ANNOUNCEMENT
MusicBee Pre-Release         information on the latest pre-releases
GENERAL
Tips and Tricks                  provide advice and tips to others - no questions please!
General Discussions           general MusicBee and forum discussions
      Child boards: Polls
MusicBee Wishlist              make a wish for what you like to see in the next version?
MUSICBEE ADDONS
Customisations                  discussing add-ons extending visuals and interface
Plugins                              discussing add-ons extending functionality
SUPPORT
Questions                          need help?
      Child boards: Support in non-English languages only
Bug Reports                       report factual bugs and malfunctions
Developers                        developers discussion board
BEYOND MUSICBEE           talk about anything not related to MusicBee
      Child boards:Rubbish Bin
AvikB
do we need poll as a child board? we can post polls in general board.
haha, 'polls' was something you brought up. You seemed to have some serious plans with it, so I just thought to give it a special place ;-)
AvikB
For serious plans i only intended it's use for voting any specific feature, or using it for getting feedback, a special section is too much i guess :P
Looking at this part, I have doubts if it is an improvement to have the announcement board split in two between 'latest official' and 'latest pre-release'.
Especially since it is announcements only, and only Steven contributes to that, I think that works well and looks clean.
But perhaps for discussing releases that are under development, there could be a child board for that under 'General'?
Steven?
ANNOUNCEMENT
Make sure that if/when using a poll to gather votes for adding specific features that there's a disclaimer stating something like "just because a feature rates high in the voting, that's not a guarantee that it will be added."
Are you working on something right now?
Some serious corruption here:
