i set the limit to 25000 in case you need to use that
I hate to ask again, but…
Even the limit of 25.000 can be a problem when posting formatted BBcode tables such as
this one and
this one.
A solution can be to split up such a post in two posts.
But here is a situation where that doesn't work well:
- you have created such a post, and after that there have been several replies to it
- then you want to add another (related) BB-code table
You can not add it to the existing post, since that one already contains e.g. some 20.000 characters.
You can create a new post for it, but that one will end up at the end of the thread, breaking continuity.
So, if it is possible (and doesn't create possible issues), I would request the limit to be raised to 50.000 characters.
edit:
To give some idea, this table is using up 1096 BBcode characters:
@karbock:
Do you share this observation, and if so, do you agree that 50.000 would be good?
