Author Topic: [WEBSITE v2] MusicBee website and forum redesign  (Read 646162 times)
AvikB
This bug still persists: http://getmusicbee.com/forum/index.php?topic=19360.msg115999#msg115999
Can't reproduce it. maybe i am looking in the wrong place.
Can you give me the url of the page where this is happening? also what browser? are you logged in the forum at that moment?
Good idea. How do we go about this? Will you set up a separate topic for that?
yeah i suppose. I am going to find the list of the images proposed here to create a poll.
There might be some people who want to submit new images. Please ask people to post it in your new topic.
Yes, from inside any topic like:
http://getmusicbee.com/forum/index.php?topic=16894.0
AvikB
Can't reproduce it. maybe i am looking in the wrong place. Can you give me the url of the page where this is happening? also what browser? are you logged in the forum at that moment?
Yes, from inside any topic like: http://getmusicbee.com/forum/index.php?topic=16894.0
it seems the issue appears ONLY if the user is not logged in. will post a patch tonight to fix it.
AvikB
No, I'm logged in now. It happens regardless.
By any chance do you have quick reply disabled? it is placed at the bottom of the page, like this:
  • MB Version: 3.6.9255 P
While you're updating things AvikB, please consider this:
Just a suggestion for the add-ons section:
Might it not be better for skins, plugins, etc to be sorted alphabetically by name as the default, rather than by posting date?
AvikB
AvikB
Just a suggestion for the add-ons section: Might it not be better for skins, plugins, etc to be sorted alphabetically by name as the default, rather than by posting date?
I will add some sorting option in the next major update such as sort by(A-Z), date modified, likes, downloads etc. But by default it will use the posting date for sorting.
This way the skin page will look fresh rather than having the same item showing on the first page every time.
It also occurs with the help menu
Disabled.
Ah, i see. I will post a fix soon.
You're right. With quick reply on, it's working properly.
AvikB
This is basically a javascript error(causing by the new editor mod), which stops the height, position calculation of the submenus.
Will be fixed soon.
OK. Sort of like a 'What's New' feature  8)
