Author Topic: No install version 2_5_5721  (Read 4084 times)
Andromeda
After unpacking and click on the file *.exe nothing happens? Is there a problem with the executabel file. I use win 10.
 older version musicBee no probs.
  • MB Version: 3.6.8878 P
shouldn't be any problems, but you could try the latest 2.5 version here:
http://getmusicbee.com/forum/index.php?topic=13648.msg98403#msg98403
Make sure you use the bottom .exe link.
Last Edit: November 12, 2015, 10:49:58 PM by Bee-liever
Andromeda
Nothing happens?
Andromeda
i mistake about the version nr, the problem is with the latest version (MusicBee_Setup_2_5_5794.zip) the other version installs without a problem.
This is an update to the previous 2.5 version.
If you have MB already installed, extract the file from the new ZIP and place it in your MusicBee folder.  Then run it and v2.5.5794 will update the existing 2.5 files.
If you don't have MB installed, download it from here http://getmusicbee.com/download.html and install.  Then follow the instructions above.
Last Edit: November 13, 2015, 01:47:08 AM by phred
Andromeda
I did what you propose, no succes, nothing happens???? The filemanager locks up when starting the instalfile (*.exe)
I wait for a next version
Did you try running it as an Administrator?
Or do you have an Anti Virus program?  Specifically Avast?  You may have to whitelist the MB exe.
Do you currently have an older version of MB installed, or is this a first time install?
Andromeda
 I have the version 2_5_5721 installed and works fine
Follow the link and instruction in my sig.  You'll be downloading a zip so no need to install.  Just extract into the MB folder and let it overwrite what's there.  You'll be up and running 2.5.5794 in no time.
Andromeda
It took a round-about way to get there, but I'm glad to hear we got it figured out.
