Author Topic: Ripping a CD, Tagging all capital  (Read 1760 times)
tsa
Hello Folks,
I'm using MB for almost four years now. Time to rip all CDs to harddisk  :)
Struggling with the tag-settings when ripping.
I just want to set all words capital, but I think there is no option for that at the point of ripping, am I right?
At the moment I use mp3tag to do this after ripping with MB as Additional Tagging Tools Plugin [1] results in some strange tagging.
Maybe someone can give me hint how to make that process of ripping/tagging a little bit smarter.
bye
tsa
[1] http://musicbee.wikia.com/wiki/How_to_Automate_Song_Title_Capitalization
My first bet would also be to use Additional Tagging Tools for your requirement to have all tags in capitals.
It might be a good idea to post your question or comments in the topic of that particular plugin.
It would probably then be helpful if you could explain there what you mean by 'some strange' tagging results.
Either you found some bug that then maybe could be addressed by the developer, or you might get some help there.
You are correct.  This would have to be done post-RIP.
A screenshot of the results would be helpful.  I assume you're using the Change Case function of the Additional Tagging Tools plugin, yes?  A screenshot of these settings would also be helpful.
http://getmusicbee.com/forum/index.php?topic=16499.msg96287#msg96287
