Author Topic: Google Search for lyrics always fails  (Read 4380 times)
Antonski
Hello,
Since recently I always get this error when I try to search for lyrics by "Google Search" option.
Does anybody have an idea where to dig in?
MusicBee v2.5.5759.32845 (Win5.1), 25 ??? 2015 0:45:
System.ComponentModel.Win32Exception (0x80004005): Application not found
   at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
   at #=qddDneDdWhHfO$dJdPMnXN4VeTZv2rzX4L9OUQ_dmTpI=.#=qa636TqZDT4Kobewb0rEAxnqgkUTY$zCZrpxl8Zm9rYM=(Object #=qln04dC1PIjLfIQqn$bTSPg==, EventArgs #=qz3_kMU3ZFBsAhvro$dH8Ww==)
i would say thats a windows configuration issue.
MB is trying to open a web link in the default browser application but for whatever reason the default web browser application seems to no longer exist, at least at the location windows has it configured
edit:
i guess one other possibility is your security software is blocking MB from opening the browser
Last Edit: October 25, 2015, 09:14:51 AM by Steven
Antonski
Thank you Steven, you are right.
After I set FF as a default browser, everything is working fine again.
It seems that something has happened with IE, but I won't waste time to investigate, I don't use it anyway.
CU
