Author Topic: Compatibility between MusicBee and the visualizer plugins  (Read 5310 times)
Helium100
Hello,
I'm an MusicBee french user. So, sorry for the mistakes :) .
My issues concerns the MusicBee visualizer system.
Some visualizer available (like soundspectrum) work well with Winamp. But it doesn't work in MusicBee (blackscreen on visualizer). Maybe, the Winamp API and MusicBee API are too diferent for those plugins?
Maybe, you should update the plugin compatibilty in Musicbee?
I believe that MusicBee isn't optimized for some new GPU/CPU architecture or/and new drivers version. Because a bug report from a plugin say that:
"WhiteCap cannot run on this computer because it lacks the required graphics hardware or because the latest graphics drivers aren't installed."
But MusicBee doesn't create a bug report as if there had not been a problem.
However, I get the latest updates (and work well with winamp).
Otherwise, Thank you for this fantastic software! I use it all the time  :) I hope you will take some time for checking and updating your visualizer system and plugin compatibility (If necessary).
