Author Topic: Skin- and visual errors related to, and skinning requests for MusicBee v3  (Read 332498 times)
Well, not on purpose then. But could it perhaps be that there is either a typo, or a remaining transparency value from the skin that your skin might be based upon?
edit,
If you are using notepad++, you can find those easily doing a regex search.
Just enter: "\d+,\d+,\d+,\d+" in the search field.
Last Edit: December 10, 2015, 05:03:44 PM by hiccup
at least "Menu.DropDown.Highlight" has 0 alpha for the colour
its possible other elements are the same
id="Content[TrackDetail].ItemSeparatorLine" doesn't seem to work anymore in v3
And a minor issue that I remember also once showed up in v2 in the past.
When opening the configuration panel on a (very) dark skin, it opens with a short white 'flash'.
This looks like it might also be a glitch.
There seems to be something very wrong with that skin. When I open it with MB v2, MB crashes, and notepad opens with a very long error text.
Could there be something wrong with the images in it?
the first was reported the other day and should be fixed for the next update
for the 2nd i dont see it. Which dialog window does it happen in?
<element id="Content[TrackDetail].ItemSeparatorLine" fg="xxx,xxx,xxx"/>
<element id="Content[AlbumAndTracks].ItemSeparatorLine" fg="xxx,xxx,xxx"/>
should be working now
http://www.mediafire.com/download/yg2iu46j3binune/MusicBeeDemo.zip
  • MB Version: 3.6.9255 P
Yep. All fine.
Would it be possible to have on override for the line that also appears when using a grouping header in Track Detail view.
It's currently auto-generated by MB
EDIT
or auto-generate a much darker line higher contrast line rather than the slightly darker lightly contrasting line it currently does, please
Last Edit: December 10, 2015, 11:42:44 PM by Bee-liever
Alumni
Thanks for the tip! I am using Notepad++.
I did the search exactly as you said, with no results. So I can say for sure my code has no 0 alpha colors.
Here's what I have for that element:
<element id="Menu.DropDown.Highlight" bg="20,20,20" bdr="20,20,20" />
No idea what the problem could be... I have only tested it in v3.
Last Edit: December 11, 2015, 04:52:06 AM by Alumni
Now Playing List overrides appear to be working now!
These elements don't show up:
<element id="UseArtworkBorders">true</element>
<element id="Controls.FaintLine" bg="143,189,39" />
I notice that in 3.0 some buttons appear to be active which aren't, such as the Configure buttons in Player Preferences.
And can we get rid of this line in Preferences that seems to be the wrong color?
Last Edit: December 11, 2015, 04:42:04 AM by psychoadept
can you send me the source xml file (i already have the xmlc file). Its defenitely reading that element with 0 alpha
Alumni
Sure, sent to you.
When opening the configuration panel.
But also when opening MB for a first time.
With e.g. the 'Sportura Pinstripe' skin it's very obvious here.
It's not happening always, but often enough to experience regularly.
edit:
This is the thread about the same happening on v2 before, which you were able to fix then:
http://getmusicbee.com/forum/index.php?topic=14746.msg87904#msg87904
Last Edit: December 11, 2015, 08:16:34 AM by hiccup
well thats what i tested a number of times and didnt see it. Of course machines/ windows setups can differ so produce different results but unless i can reproduce it then i cant fix it. Can anyone else confirm this "white flashing" when opening dialog windows on dark skins?
i had a look at the source file you sent, and compiled it. The menu element was fine with that one and couldnt reproduce the glitching i was able to reproduce before
Alumni
Edit: Ok I think this might clear things up.
<element id="Menu.DropDown.Highlight" bg="20,20,20" bdr="0,0,0" />
This line of code creates a border with the intended color: 0,0,0.
This line of code creates a border with an unintentional color: 120,120,120.
Last Edit: December 11, 2015, 11:03:38 AM by Alumni
