Author Topic: Skin- and visual errors related to, and skinning requests for MusicBee v3  (Read 330920 times)
Can you tell us at least which element the bg of expanded panel in artwork view is based on when auto-generated with auto-pick color option disabled?
I want to make it much darker for some of my dark skins, but cannot find a way.
its based off the artwork panel background colour: Content[Artwork].Body.Default
and is made slightly brighter or dimmer depending on whether its a dark background
edit:
i will add in an override:
  <element id="Content[Artwork].Expanded" bg="210,210,210" fg="0,0,0" fg2="255,0,0" />
where fg2 is for the Album Text
Last Edit: March 26, 2016, 02:50:37 PM by Steven
Thanks, but the new element is not working (no difference). Tested with multiple skins. Can you check please?
Still not working with the latest patch. Can somebody else confirm if it's working?
well i am using it in the default skin now so i am quite sure its working.
If the default skin is not showing a background of 225,225,225 then you dont have the correct version
i think i must have uploaded a slightly old version. Could you download again
KissCool
"MainPanelSeparatorMargin" doesn't work anymore or am I doing something wrong?
Those elements seems broken too (or aren't supported anymore):
<element id="MainPanelMargin.Top">2</element>
<element id="MainPanelMargin.Bottom">2</element>
<element id="MainPanelMargin.Left">2</element>
<element id="MainPanelMargin.Right">2</element>
Whatever the value, there is no margin. If I remove them from the skin file, the margin appear.
KissCool
This one still doesn't work:
<element id="MainPanelSeparatorMargin">7</element>
(the others are fixed, thanks)
