using a gradient on mini player produces all sorts of problems in MB3
i actually didnt intend to support that but forgot to disable the bg2 via the skin settings. However it turns out to be straight-forward so its done for the next update
thanks! looks brilliant
could we have overrides for the new Last.fm Recommendations and Statistics navigator icons, please
and I'll try to twist your arm
I'm begging you to reconsider just <element id="AutoDjPanel.Default" bg="xxx,xxx,xxx" fg="xxx,xxx,xxx" />
(or maybe a new MB3 override! huh!! huh!!)
Please, please, please...
(I'm grovelling now, in case you hadn't guessed)
