trying to get those damned lowlight scrollbars to work for Wing-ated and have run across a bug.
If you have made some changes then can you send that to me
The problem is there's no such element as Menu.CommandButton.Pressed to specify button colors when pressed.So can you make the fg of the button follow Menu.CommandButton.Selected when pressed?I can't think of any side effects that change might cause.
if colours are supplied for the override<element id="Content[Artwork].Expanded" bg="23,23,20" fg="166,133,85" fg2="141,96,65" />should the bg colour be used for the intermediate panel (when shown) and 'auto-pick panel colours' is also selected?
Quote from: redwing on April 12, 2016, 04:12:46 PMThe problem is there's no such element as Menu.CommandButton.Pressed to specify button colors when pressed.So can you make the fg of the button follow Menu.CommandButton.Selected when pressed?I can't think of any side effects that change might cause.i figured out how to better detect the state shown in your example and from the next update it will use the selected fg instead of the default fg colour
But there's another bug related to this, which took me quite a while to figure out what's going on:The bg of the pressed button becomes invariably 180,180,180 if main menu is shown as a button (requires relaunching of MB). If it's shown as (inline) menu bar, it's working fine.
Quote from: Bee-liever on March 10, 2016, 01:26:02 AMQuote from: Steven on March 05, 2016, 12:24:20 PMjust while i remember - i am adding an optional bg2 to these so you can get a fade effect<element id="Content[TrackDetail].HeaderLine" bg="235,25,25" bg2="245,245,245" /><element id="Content[AlbumAndTracks].ArtistSplitterLine" bg="235,25,25" bg2="245,245,245" />and adding this for the new artwork grouping<element id="Content[Artwork].SplitterLine" bg="235,25,25" bg2="245,245,245" />with these new elements (which I love BTW) the brighter of the 2 colours leaves 1px dot at end opposite to main part<element id="Content[AlbumAndTracks].ArtistSplitterLine" bg="9,20,37" bg2="58,113,207"/>if you reverse the colour values the dot appears at the RH endQuote from: Steven on March 10, 2016, 09:13:17 PMtwo separate issues - the dot is fixed for the next update and the different element used for when left & right headers is so you can control the fading if its just a left only header vs. a left & right headerWorks fine when the dot is on the left.Doesn't work when the dot is on the right ("Album" and "Album & Tracks". "Tracks" is OK)
