Author Topic: Skin- and visual errors related to, and skinning requests for MusicBee v3  (Read 331067 times)
Highlight was probably not the best name. Its when the row the playing track icon displays is selected
It only changes in Track Detail view.
Bug or by design?
Fot the Album and Tracks layout in the main panel the icon should not be painted against a selected row background
  • MB Version: 3.6.9255 P
I must be a bit thick today, I'll try with pictures :D
that's on selection!
Is this how it's supposed too be?
there is a small bug in the right sidebar Track Thumbs layout where it doesnt use the selected track playing icon.
That icon is only used if the panel is in focus
edit:
looking at the picture i think you might not be understanding what the selected track icon is for.
Imagine you have a white background and black icon. If the selection bar is black then you need a different colour for the icon. That only is needed when the icon is covered by the selection bar
Last Edit: January 24, 2016, 02:33:18 PM by Steven
The second is still present:
To replicate:
Have a toolbar command button for "show artwork", and press it without having any files selected:
i have added "ConsolidateButtonsIcon" for the next MB3 update
it will be automatically recoloured to the same colour as the existing icon
Last Edit: January 26, 2016, 09:37:33 PM by Steven
edit:
I'm aware of the intended use of the icon, I just chose to use it in a different way for that skin :)
a part of <element id="TabsBar.BorderLine" shows under the close button on the tag editor floating window
And TabsBar.TabInCaptionBar.BorderLine shows at the same place on preferences window.
With version 3, when a track is started, a small gap is created in the left side of the progress bar fill element:
I tried a lot of things, and I can get rid of the gap when I make the progress button less wide, but that will affect, and cuts-off some pixels from the left side of the progress bar element, and this:
becomes this:
Maybe it's something in the xml file, but I tried lots of things and can't figure this out by myself.
(pm send with all relevant skin files in case you could look into this)
endeavour1934
I noticed the same. Also noticed some distortion on the ProgressBarButton as it moves, but only if the visible part of the image reaches the image border (with transparent pixels on the border there is no distortion)
Last Edit: January 28, 2016, 05:03:24 PM by endeavour1934
I noticed the same. Also noticed some distortion on the ProgressBarButton as it moves, but only if the visible part of the image reaches the image border (with transparent pixels o the border there is no distortion)
Thnx for confirming, this stuff often makes you doubt yourself....
would either you mind sending the skin in question as i cant reproduce this by applying that element
i can reproduce using your skin and will attempt to address it
You can test with any of my 2.5 skins, like Pastels. But I only saw the latter, not the former.
