Author Topic: Skin- and visual errors related to, and skinning requests for MusicBee v3  (Read 331130 times)
  • MB Version: 3.6.9255 P
yep, seems i still didnt have it quite right. It should be working consistently with v2.5 for the next update
working perfectly! Thanks for the hard work :)
it looks like windows is overriding the disabled colours but this works around that:
That indeed seems to fix it for v3. (v2 still has it)
How dare Windows interfere with our beautiful coloring schemes.
The highlight border in track details shows only on top of the line, not on the bottom.
edit:
This is in Album and Tracks view. In Track Details view it's o.k.
Last Edit: December 29, 2015, 06:02:09 PM by hiccup
The bdr element for id="Controls.Button.Highlight" doesn't work.
I believe this was the same with v2.
If it's by design, please add it.
would you mind sending the skin so far
where are you checking this? its working fine for me
In the Preferences panel.
(in the skin I send you) 'Apply, save, close' don't seem to respect the bdr value of:  id="Controls.Button.Highlight"
yes you are right - i missed the bit about the bdr attribute
Should the Apply button in the tag editor have a "lowlight" cover with there's nothing to apply?
thats a good idea but not a trivial change as it would require recording any change made (the Close button should also change to Cancel), so i doubt i will do it at least for now
