Author Topic: "null - Entanglement" synchronization hangs  (Read 3053 times)
enrican
I get this whenever I try to synchronize my Samsung S6 Grand
It starts doing some good operations as deleting and copying when in some place I get this into the synchronizing task list and the synchronization seems to stop. Musicbee is still usable but I have to abort and restart music bee to try to synchronize again...
Here I link to two screenshots that helps to explains this.
https://goo.gl/photos/nH5yVA4MbRmDdFKT7
Samsung S6 Grand
Windows Vista Business
MusicBee 2.5.5721
Hi, welcome to the forum!
Do you know what file that is?  What happens if you remove it from the sync list? (you can sync your library as a playlist and exclude that file, if you need to)
I think that whatever file is trying to sync at that point is corrupt.  As psychoadept said, try to eliminate that file from the sync process.
