First, the normal stuff. I am using version 2.5.5708. View is set to Main Player only and theme is MusicBee Standard. I have the last.fm, cd art display and discogs plugins enabled. I encoders installed for all conversion types. My main view (the whole screen, is album art cover with 2 lines of text under, album artists then album.
Here is my problem. I have many albums that have subfolders. These subfolders are normally wanted to be included, like a CD1 and CD2 type thing. Some subfolders however, I do not want subfolders included. These folders mostly contain added content like HTML extras. The problem is they include audio data and MusicBee includes them as a separate album. My grouping is set for each album to be organized into its own folder, which it is. I am able to manually delete them from the library, but each time I update the library, I need to go through and find them all again and delete them.
I did find that I can select folders in the Choose Folders option when Scan Folders for New Files is used. Problem is that when I do this, I browse to the main folder that should be included, expand it and deselect the subfolder, it also deselects the main folder. Once all are not selected, if I select the main folder, it includes the subfolder. So, it appears I cannot deselect subfolders within an included folder.
My music file structure is as follows:
<DRIVE>\Music\Full Albums\<ALBUM>\<ANY_SUBFOLDERS>
My starting selection is to include the entire "Full Albums" folder.
A directory tree is as follows:
>Full Albums
> Album 1
> Unwanted subfolder
> album 2
> wanted subfolder
> album 3
> album 4
Any help would be appreciated. If more details is needed, just ask. Thanks.
