Author Topic: How to get rid of dead files in 2.5?  (Read 1973 times)
ethereal12
There used to be an option in "Rescan Files" to remove dead files, but it seems that's gone now.
Is there a different way to do it other than manually?
I think it should happen automatically now.  The only exceptions would be if they're in a playlist or if the drive they are on has been removed.  I think.
ethereal12
I moved files from one drive to the other. Anyway to get around it?
File > Library > Remap Music Folders
Or, if you've already imported from the new location, just sort by Path so you can get them all together for quick deleting.
