Author Topic: How can I use my wireless speaker?  (Read 3711 times)
billynomates
Please can someone tell me how to play songs over my wireless speaker using MusicBee?
I can do this easily with windows media player by right clicking on the file and selecting Send To, but I would rather use MB and I cant work out how to do it.
Thanks
  • MB Version: 3.6.8878 P
right-click on the player bar and you'll get the "Output To" option.
your wireless speaker should be available in the list of devices
billynomates
Thanks for your reply, do you mean the bar with the player controls play/stop etc, I dont have an 'Output To' menu.
There is a 'Send To' menu with nothing obvious inside it (the Devices option is greyed out).
In Preferences > Player > Output there's a choice of Direct Sound, ASIO, WASAPI, Import Winamp plugin. None of these seem to work.
If it's a UPNP/DLNA device you'll first need to install the plugin from the Plugins forum.
billynomates
Thank you Zak, I installed plugins and I now have the option to send music to another device!
