So for some reason when i re scanned my library all my playlists shat themselves and decided they don't know where the files are (even though in the playlist's notepad file all the tracks are correctly linked) how do i find multiple tracks all within the same windows folder? similar to what itunes does when it say's "would you like to use this file location to locate other missing tracks"
So my question is. Is there a way to re find multiple files at once?
