Author Topic: How to Make Custom Tags (Release Format)  (Read 6524 times)
AugustHouse
Hello MB Community,
I've been using MusicBee for 2 weeks now and I love it so far. However, after searching around past threads in the wiki and the forums for a while now, I still haven't been able to find a simple, step-by-step description of how to make custom tags. Could anyone help me? Specifically, I'm trying to tag my music so that I can sort by Release Type/Format (Album, EP, Single, Live, Compilation, etc.).
Thanks in advance!
Alumni
Welcome, I hope these instructions are simple enough to follow.
Go to Preferences, Tags (1), then under the "custom tags" section click on "define new tags..." In the top section of that window, type in the name of the custom tag you want to create and press tab to copy it to the rest of the columns. Next click save. Go back to the Tags (1) "custom tags" options and pick an empty custom tag slot, for example "Custom 3". Type the same name you entered before, then click the drop down menu to select the name of the tag you created a moment ago. Click save or apply, MusicBee should then re-scan your library. Now when you right click on an album or song to edit the details, you should see a new entry for your custom tag under "Tags (2)". If you want to sort your view using the new tag, you can do that by right clicking the "sort by" header and "define custom sorting..." option. Select a blank entry and using the drop down menus you can select a mixture of default tags and custom tags to fine tune the sort order.
There is also a tag "Media Type" which sort of fits that description. I think it's actually meant to refer to the physical medium (and now digital), but I use it to separate albums, singles etc.
AugustHouse
Thank you Alumni for the very clear process of how to do it and thank you Zak for the tip! I'm currently going through my library adjusting the tags and it seems to be working exactly how I want it to, after a small tweak (adding /year in custom sorting). Thanks again for all the help!
Where exactly are you seeing the Media Type tag?  I opened the Tag Editor and looked at Tags and Tags (2) and don't see it.
It's in the custom tag list.
Got it.  Thanks.
It's not a new custom tag I created, so I thought it must have been included with a vanilla MusicBee install.
For the OP, I see you probably still have to give it a name and select it on the custom tag list like this:
You could also call it something else if you prefer.
