Author Topic: How to get rid of music files containded in a folder removed form MusicBee?  (Read 10190 times)
OK, then there's no track in your library. Now you said you wanted to import not all files but some files in specific folders, right?
Then let's do that.
1. Click on inbox node, select all tracks and remove them (only from inbox, not from computer). Then you will have no files in your library & inbox.
2. Run "Scan folders for new files" command. Tick all folders that you want to import files from. Tick "add to library" option.
Then you will have the files in your music library that you wanted to import.
Biff
Many thanks, redwing.
<<<OK, then there's no track in your library.
Hmmm, but why does MB show there are:
http://i.imgur.com/vAXjC2O.png
http://i.imgur.com/aayxUSb.png
http://i.imgur.com/59Dpx2i.png
<<<<<Then let's do that.
<<<2. Run "Scan folders for new files" command. Tick all folders that you want to import files from. Tick "add to library" option.
Is it correct, the same result I would get when I drag music folders and drop them over MB?
<<<Then you will have the files in your music library that you wanted to import.
Done, now it looks: http://i.imgur.com/yQWIXeR.png
How could I let MB automatically remove entries of files being removed / not existing anymore? And when I do not want to have special (still existing) music folders be displayed in MB, how could I remove the entries of special music folders form MB?
Many thanks.
Last Edit: May 23, 2015, 12:10:35 PM by Biff
Newest portable, stable MusicBee - Windows 10 Home, 64bit
What do you mean by special music folders? Where do you see them?
Biff
On my hard disks, external / internal drives. So, just normal folders. Special folders, means certain folders, not all of my folders, may be a few folders of them, some of them, one of them, etc.
Just select files in the music library that you want to remove from the library, and remove them (not from computer). If you need to see each file's folder, then add "path" field to the main panel.
Biff
Thank you very much.
<<<<<Just select files in the music library that you want to remove from the library, and remove them (not from computer). If you need to see each file's folder, then add "path" field to the main panel.
Yes, but I do not want to do it manually, so how could I let MB automatically remove entries of files being removed / not existing anymore?
Why does MB show there are:
What does that mean?
Thanks a lot.
Read this: http://getmusicbee.com/forum/index.php?topic=7974.msg78665#msg78665
It rescans all files it knows.
I wouldn't recommend it because sometimes you will get unexpected results depending on your settings. For instance, drag & drop on the same drive could move folders instead of copy them.
Biff
<<<<<Quote from: Biff on Today at 02:42:31 PM
<<<It rescans all files it knows.
I am not quite sure to understand:
But it shows there are. Why does MB do that, what is the reason to show it, if there are not any files in the library?
<<<<Remove Unmarked Dead Links in the Library
If you delete music files with MB closed, MB database could have discrepancies with your actual music files. In that case, MB won't correctly mark those non-existent tracks as dead links until you attempt to play or edit them. There are several ways to resolve this issue.
(1) Tick "on startup check for updated or missing files" option under Preferences> Library
(2) Add your music files folder to the monitored folders setting under Preferences> Library
(3) Run Tools> Advanced> Rescan All Files command to update database
Thank you for the link, yes, I had already activated those options, but had not get it to work, may be I am able to get it now: http://i.imgur.com/2QyOWs2.png
<<<<Is it correct, the same result I would get when I drag music folders and drop them over MB?
Alright, just use "Scan folders for new files".
So the folders are moved / copied instead of their files just will be added to MB (whereto, to what folder are they moved / copied?) ? That would be extremely adverse. I had understood dropping the folders / files will cause an entry of the files in MB. That is not right?
