Author Topic: How to manually update / refresh the library?  (Read 28367 times)
Biff
How can one manually update / refresh the library?
Newest portable, stable MusicBee - Windows 10 Home, 64bit
Probably the fastest way is to select all files (shortcut ctrl-a), right click, choose rescan files.  You can also set rescan up with a button or hotkey.
Biff
Thank you, psychoadept,
Hmmm, but the new music files in the music folders not being scanned / in the library already would not be selected doing it that way, but they would be added to the library anyway?
And I have removed a music folder (it is not shown anymore in MusicBee) but its music files are displayed though. Why is that? How can I delete them from the library?
Where can I find the "rescan" option?
And how can one see the updating of the library is still running? The amount of scanned items obviously increases but I cannot find any display the process is still running.
Thanks again.
Last Edit: May 20, 2015, 10:23:22 PM by Biff
  • MB Version: 3.6.8878 P
If your using v2.5, library rescan can be found:
Tools> Advanced> Rescan all files.
If your using v2.4, from memory, it's located here (I think):
Files> Library> Rescan files.
You have to select the option to re-scan files already in library.
Biff
Thank you.
I use the newest portable, stable MusicBee.
Sorry, I am not quite sure to understand.
Whatever I do rescan, rescan at startup etc. the amount of music files stays the same although I changed / added / removed the music folders? Why is it like that?
Thanks again.
Last Edit: May 21, 2015, 08:52:00 AM by Biff
The latest version of MusicBee is available here: http://musicbee.wikia.com/wiki/Latest_Update
The download page is actually a fairly old version, but Steven is waiting to officially release 2.5 until the 3.0 beta is further along.
Biff
Thank you for the link. That appears to be a beta version or something like that. The newest stable one seems to be this one: http://getmusicbee.com/download.html
And I want to use a portable version.
<<<The download page is actually a fairly old version, but Steven is waiting to officially release 2.5 until the 3.0 beta is further along.
Oh, that means I use an old version? Do I understand it right, this version - http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip - is the newest stable, portable version?
It's just as stable as 2.4, and you can apply the patch to a portable version exactly the same way as the regular version.
Biff
Alright, strange, I will try it, many  thanks.
