Author Topic: Same version, different PC, two different results  (Read 2115 times)
markzzz
Why on the same file (shared across my LAN), below the Genre tag (into the Horizontal's Column Browser), on my laptop I can see the ID3 written on the main Edit window + the tags into the Tag Inspector (so multiple Genre tags in the list),, than on my Desktop I can just see the tag into the Edit window (so only 1 genre tag line)?
Seems it ignores the tags inside Tag Inspector.
Same version of MusicBee.
Is there some options that I didn't checked?
Can't speak for anyone else, but I didn't know what you were talking about.
A screenshot from each PC would help.
J24
  • Love music of all genres and cultures
If I interpreted your issue correctly, the problem is that one PC you are using the "Genre" column and on the other one you are using the "Genres" tag (with an "s" at the end). "Genres" displays all the genres and "genre" only displays the first genre.
I'm addicted to meth, that is, methadata.
Wanna share music recommendations? add me on Last.fm!
