Author Topic: Old Sonique for MB  (Read 79151 times)
  • MB Version: 3.6.9255 P
Here are 55 old Sonique visual plugins I have collected, tested (on MB 2.4 and 2.5) and renamed for use in MB.
Includes:
  • Acidspunk
  • Corona
  • Faited
  • Rabbit Hole
  • Scope
and other old favourites
Just unzip into the "Plugins" sub-folder in your MusicBee installation folder.
Download available here
Last Edit: June 10, 2015, 10:12:26 PM by Bee-liever
I'm not a programmer by any stretch of the imagination (still working on the first chapter of C# for Dummies  ;) ) but I do have a copy of a Sonique visualiser plugin test file that is in a MS Visual Express project form.
If anyone wants to try writing a new visualiser for MB, just give a yell and I will post it to them.
Over 100 downloads  -  less then a month  -  no comments   ???
Guess that disproves the statistic that only approx 1.7% of internet users say "Thank You" for resources provided to them for free   :P
Thanks boroda74   :)
I guess my results are there to keep the statistical average below 2%   :D
actually i'm sad that most people don't want just to say thank you for your work. at least i'd know that my plugins worked correctly.
Stang777
Thank you for providing those files from Sonique, but I cannot get them to work.
I was really excited to get Rabbit Hole, as that is the one that I have always liked the best, and have never been able to find a visual that I like anywhere near as well, but it doesn't work. Most of the Sonique visuals just do nothing in this program, but Rabbit Hole actually gives an error.
They show up in the program to be used, but they do not work. I have tried putting them in different folders, just in case, but the Plugins folder you said to put them in is the only one that makes them show up in the player.
If you know of something that I can do to make them work, I would appreciate you letting me know.
I do appreciate the effort you put into making them available. :)
Last Edit: June 10, 2015, 09:48:19 PM by Stang777
What version of MB are you using?
blockhead
I just downloaded.  Thanks for the fantastic visualizers.
They all seem to work just fine, although I have to "un-tic" Show Visualizer then change to a new one.
If I just select a new visualizer without un-ticing Show Visualizer then nothing happens or the plugin crashes.
I am using MB ver 2.5.5575
Stang777
I just tried what blockhead had to do to make it work and that did not work for me.
Where are you guys getting a later version than what is listed on the download page on the Musicbee website? Their download page says it downloads this
Latest Release Installer
Version:   2.4.5404 Update 1
Date:   18 October 2014
Platform:   Windows XP/Vista/7/8
This is the error I get when using the Rabbithole visual...
MusicBee v2.4.5404.16303 (Win6.2), 10 Jun 2015 17:49:
System.OverflowException: Overflow error.
   at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
   at System.Drawing.Graphics.DrawImage(Image image, Point point)
   at #=q1mqN6bfJHVIEZsqkhCqpSIk9KcwuqNwEmoBQ_XKI_AoFyddU6tILIpRqQz8ozLVK.OnPaint(PaintEventArgs #=qiE0FKERQLtrpTj7X0VhtJw==)
   at #=q9DbaPkf98Bwnsb8WzYcjp0RNJK2ABsR7K3qLJHpRAZU=.OnPaint(PaintEventArgs #=qoAz95QKSZnRpO3jFmzUSVg==)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=q1mqN6bfJHVIEZsqkhCqpSIk9KcwuqNwEmoBQ_XKI_AoFyddU6tILIpRqQz8ozLVK.WndProc(Message& #=q74ZEvgfBvQT2FhHjTEMo8A==)
   at #=q9DbaPkf98Bwnsb8WzYcjp0RNJK2ABsR7K3qLJHpRAZU=.WndProc(Message& #=qoXVQg9iOWBjrD9gqwcVc3Q==)
Follow the instructions in my sig
@ Stang777
If they still don't work after updating to MB2.5, you may need to delete the vis.ini file from the plugins folder and re-start MB.
Stang777
Thank you so very much, that worked. :)
Like Blockhead, I do have to uncheck the start vis option before changing them or the program crashes or there are errors, but as long as I do that, the ones I have tried work great.
I had to give up Sonique when I went to Windows 8 as it wouldn't work and I have missed it. No other program had visuals I liked but now, thanks to you, I finally have my Rabbit Hole back. Yay!
I appreciate you making the Sonique files available for this program and for helping me make them work, thank you again :)
Glad we got it sorted for you  :)
Thank you blockhead and phred for helping out.
