Not exactly what I was looking for but it is a good compromise. ThanxI was hoping to visualize the Column brouser as folder structure
How to Create a Virtual <Folder> tagIf you frequently access and play files from their folders, MB's Computer node in left navigator might not offer desirable functionality for navigating and quick-accessing different folders. Then you might want to use a virtual field starting with the folder name you'd like to populate.If you have a folder structure starting with E:\Music\Adele, Folder = $Replace(<Path>,$Left(<Path>,9),)This would return "Adele\..." value for each track. So replace the number 9 with any number depending on your folder structure.If you have different folder structure according to genre, etc., you can modify the formula above using $If syntax.Now you can add this "Folder" virtual field to library explorer, track browser, or main panel for easier browsing. The difference between this and using the tag (in this case "Artist" tag) is that this directs to the corresponding folder instead of a group of tracks corresponding to the tag value.
Sorry, I did not understand your suggestion...
Then enter this: Folder = $Split(<Path>,\,3)
The result is almost perfect except for one thing: before the name of the artist there is: "folder ="
Redwing was suggesting a virtual tag called Folder with the formula $Split(<Path>,\,3)Take the "folder = " bit from the start of the virtual tag formula and you'll be all good.
