Hello - A fairly new user of MB so apologies if this has been covered. I did a few searched in the forum before posting however. Ok, here are the basics of what I would like to do and I am looking for feedback on how others handle this scenario.
- I have my primary music collection where all my devises get their content
- I have an on phone I use as my mp3 player in the car which needs updating from time to time
- I have other devices in addition to the car player that I'll use with music be device sync once I decide on the best way.
Should I use the two library function, main and mp3 player, or should I use one library and create a playlist or some other way of removing and adding content using the sync. My initial stab at this was using two libraries, but I ran into what I'm discovering is a newbie problem. I had the mp3 player library (library b) set up to autosync on startup, but once I had it synced, I moved back to the main library ( library a ). So today I decided to put the whiplash soundtrack into library b. I connected the device, opened MB and it started syncing as advertised, BUT I hadn't switched to library b so it started to sync my library a to my devise. This led to this post. I hope I explained what I am trying to accomplish and what I am trying to set up to not happen again. I did set up library b to sync my device manually for now.
Any input is much appreciated and I am thrilled there are still high quality open source solution to my obsession if organizing, tagging, and syncing my music.
Thanks,
