Hello,
I had been using Media Monkey until recently. I switched to MB because of the good reviews, the light foot print and because Media Monkey crashed consistently. However, among the tools within MM was the ability to create editing statements to cleanup large numbers of files at the same time. Batch editing in the extreme. The problem though, was you really had to know syntax language, etc. to be able to configure these statements (rules). There was no help any where that I could find. I gave up on this feature and then gave up on MM because of the crashes.
So, the question is can MB perform this type of function? I have over 70,000 tracks. Yes, the number is correct 70k. I know however that many of these track are dupes or dead files or mislabeled. I really need help to get this under control but I don't have the programing skills to make it happen. Does anyone out there have any ides? Thank you very much for reading my post.
