I'll try the suggestions given in the link kindly provided which I believe are -
To get what you want:
<auto-sync settings>
- Untick Music Library.
- Tick the playlist you want to sync only.
<device settings>
- Storage path: H:\
- Playlist path: Music\
- Tick the "Create a sub-folder..." option.
Now click on "Synchronize" button.
Just to recap, what I would like to get (if possible) is the same sort of structure I see when I browse Playlists in iTunes which is
Playlist1 (Artist's name)
Song1 Title
Song2 Title......For album #1
Song1 Title
Song2 Title.....For album #2
Playlist2
....and so on
Will the above settings achieve that or is a tweak needed?
One further question, is the Sync process 'incremental'? In other words, suppose in the above example I add another album to the playlist for Playlist1 in iTunes. With the USB disk attached, what steps need to be taken to get this new album in to the playlist stored on the USB disk? Import the Library again and do another Sync? Apologies if that's a dumb question!
Many thanks
