Author Topic: Library Explorer - Artists' Multiplication  (Read 4819 times)
antietam
In my library, I have both Boys and THE Boys (different bands). Now these are displayed as shown below - with 15 entries each.
Version 2.5.5517
  • MB Version: 3.6.9255 P
I can confirm it happens
"The Pointer Sisters" when they where a quintet/quartet (2 albums total).
"Pointer Sisters" when they where a trio (4 albums total).
I always assumed it was to do with having "The" as an ignore word for sorting and would be a bit of a problem to fix.
that should be fixed for the next v2.5 update. I cant reproduce the other issue you reported though. Perhaps its related but if it stll happens can you post a screenshot. I will post an updated musicbee link later
unzip and replace the existing musicbee files.
If the other problem still happens then can you PM me a link to your settings (help/ support/ view settings)
antietam
Thanks, the names' multiplication problem is solved, the other one is still there. Sending you a PM with my settings.
antietam
Version 2.5.5517
Exactly the same problem has reappeared in version 3.0.6073.
before i look at this can you confirm its happening with the latest patch version
antietam
Yes, it's happening with the latest patch dated 2016-08-18 12:17.
