Author Topic: GUI changes for v3.0  (Read 1404892 times)
9ido
ok, well that took a long time to figure out and its fixed for the next update. To make things easier for me going forward could you send me your settings file if i ask for it? Otherwise i end up spending a lot of time trying to guess what the issue might be and it turns out you are likely separating the command buttons from the tabs bar which is not a common setting.
fixes for the issues above:
http://www.mediafire.com/download/yg2iu46j3binune/MusicBeeDemo.zip
9ido
Well, of course, whatever i can do to help you. But you said I should send it if my font was larger than 9pt, which was not the case, so I didn't think you wanted it.
And, check, it's fixed. Thank you. :)
Boile
Hi Steven,
the Double Click issue is fixed but I have found another one!
In Radio Tab, if i try to save a new Station, the entry appears in the List not immediately, and I must turn off or change Tabs repeatedly,
until I see it in the List
Thanks
3.4.7586
In the Tags 2 dialog for auto-tagging lyrics, the providers are not being shown in the order as configured.   There are also numbers without providers listed. In this screenshot, I have AZ Lyircs first and Gracenote second.  In the lyrics field, those providers are shown as third and seventh, but with no providers listed as first, second, fourth, etc.  Would this be because not all the providers in v2 are available in v3?
This is how it appears in v2.
@phred, would you mind sending me your settings file.
Although i cant check right now that does look to me like you are mixing the lyrics reloaded plugin and my plugin (mb_lyricsplugin.dll)
9ido
Could it be possible to have lyrics displayed in the right sidebar?
Just drag the lyrics element to where you want it.
It looks like Lyrics Fetcher plugin is enabled while Lyrics Reloaded and mini Lyrics Helper are not.  And although mb_lyricsplugin.dll exists in the Plugin directory, I don't see in in the Plugins preferences window.
PM sent with link to settings file.
9ido
Thanks. I guess I was sleeping..  :-[
Anyway, I have found a little flaw that's related,
I have the sidebar on auto-hide. When I choose 'customize panel' from track information, lyrics and so on drop down menu, the customization panel is displayed mid screen, thus outside the sidebar area. But, when I move the mouse outside the sidebar, both the sidebar AND the customization panel disappear. So you never will be able to make any changes because you just can't get there, as long as the auto hide function is on and the width of the sidebar is not great enough (mine is about 1/3 of the screen and that's too narrow.)
9ido
I had stacked the lyrics and track info in the sidebar as tabs. Upon clicking a tab this happened,
MusicBee v3.0.5818.39503 (Win6.3), 7 Dec 2015 18:24:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at MusicBee.MusicBeeMain.#=qY8E9aHu2sVJAy83O_rFCoxSrD1jM3cx$1Tg2IK$ot_k=(#=qC2$DhMLuRafdreXiqJBBsDcDUDIpADsFcUtIcIwv2h4= #=qbZFv7CApYkKJqiiBBegDaQ==, Point #=qmgo5AACuFLL51RyrMlogpw==, Int32 #=qwOos3oiBSl1ykhaGKkMkPQ==, Int32 #=qFH89WFe$H3SnUi8VgRNCqg==)
   at MusicBee.MusicBeeMain.#=qyxva8Lh0T7BQuD$QruLQ673lKGZSv40Jxl6aNLf1j0g=.OnMouseClick(MouseEventArgs #=qzdB1ewEyA2jv219GLtsT2g==)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=qp_CThkkICUE1s$oucqn6AzwtV38FOg_tW1ywMlnCczg=.WndProc(Message& #=qrvG08clM2N8qob6nb8Hacw==)
"Lyrics fetcher" is mb_lyricsplugin.dll
as you say, the lyrics reloaded plugin is disabled but you must have previously configured it to include various lyrics providers. Because its no longer enabled the previous lyrics settings become invalidated.
I might make a change to improve handling in that scenario
I don't recall configuring the providers in v3 but I might have.  I -think- it just brought in what was in v2.
Do you see any issue/conflict with having more than one lyrics plugin enabled?
