i just reuploaded the files, so could you try again. If it still doesnt work i will rebuild them. I am not claiming the issue with your optical drive showing tracks in the main panel is addressed as i made no changes for that and i cant reproduce any issues with mine, nor did i make any changes around that functionality
Downloaded once again. No difference. Behavior is exactly the same.
EDIT: Slightly different behavior, but not in a good way. After I delete the files that are showing in the Inbox (even though they've already been deleted by whatever is going wrong) the Inbox count doesn't clear. Even after moving to a different node and then back to the Inbox. And after exiting and restarting MB, not only is the Inbox count still showing, but the tracks that don't exist are showing in the inbox also.
EDIT 2: When I tried to edit an Inbox file that "doesn't exist" it opened up the Tag Editor and the Properties tab shows that the track is in the folder that I designated as the Inbox. But the track isn't there. When I right-click on the track and select Locate in Windows Explorer it takes me to My Documents. And I still can't find the files. When I did Search > Locate in Computer Node the tracks in the Inbox disappeared.
ps. I managed to get my .NET working again but only after a system restore. However i dont think this is a general problem otherwise the forum would have had reports of problems and i havent been able to find any reports of problems on the web
Great news. JOOC, did you do a restore from a backup app, or did you use the Windows system restore point?
