Author Topic: GUI changes for v3.0  (Read 1405310 times)
Boile
Hi!
In Radio view i can´t mannage to arrange the playings track pannel and i can not switch between stations with double click!
Can somebody help me or it´s a bug?
Thanks
3.4.7586
After updating to the latest patch, the text in the main panel (album cover view) now has a left alignment rather then centered.
that was an intentional change but wanted to see the feedback as i dont really want to add it as another option
sounds like a bug. I will have a look at it tomorrow
I've always been a mostly "centered" person and didn't think I'd like this.  But I almost do, and think I can get used to it.  So I'm sort of now leaning to the left.
Alumni
Oh I see. For my 2 cents I'm strongly in favor of centered alignment. Is it possible to change that setting in the config file?
Blackened
Okay, I'm having problem transferring my music to removable disk.
The left thumbnails supposed to pop up if your cursor move on the left side right? I tried it and I couldn't open the left thumbnails to transfer the songs. :(
i have had a quick look at this and double click works fine for me. You will need to explain more for what you mean by arranging the panel
to center i will put it in as <AP_TextAlign>32</AP_TextAlign>
Now if I use Auto-Size columns on the custom view, it is not saved, though.  The columns revert to previous size on restart, or even navigating away.
i am not able to reproduce this. You did this in the main panel for the library (any filter selected?) for an Album & Tracks custom layout?
Last Edit: November 06, 2015, 06:28:24 PM by Steven
It is a filter with a custom album & tracks view
Well, MB 3.0 weathered a dance party tonight!  My friends had no problem searching and queuing songs without much instruction from me.  The only thing that didn't work as expected was that when I tried to turn on the compact player, MB disappeared.  I think it tried to activate compact player on my second monitor, which wasn't there.
p.s. I'm loving "Music Explorer".  It's already helped me identify some albums I need to get.
  • MB Version: 3.6.9255 P
speaking of the compact player, is the Theater Mode option not functional yet?
Boile
Hi Steven,
The first Doubleclick is ok, but if I want to change between stations then the doubleclick does not works any more !
3.4.7586
i have no problem with that either. Maybe PM me a link to your settings file (help/ support/ view settings)
Spiron
I am getting an error with the tag editor when called from the Playing Tracks list.  Clicking the previous and next buttons with the dialog move the selected entry in the list but the content of the dialog remains the same.  It does remain pointing only to that track because if you edit any of the tags they will only apply to the original track.
do you mean it doesnt work at all or is there an actual error dialog. If there is an error, could you post the error dump.
Otherwise the bug is fixed for the next update
yes the monitor checking was missing from the compact player and is corrected for the next update
i still cant reproduce this. Is it only the auto-size menu command not working eg. if you manually resize columns does that work?
having the left sidebar popup when dragging items is not currently supported (nor in 2.5). At some point i will have another attempt at getting that to work but not promising
Last Edit: November 07, 2015, 12:25:14 PM by Steven
ankor
On the left sidebar, if I click on a filter (under Music) and put it into edit mode and then click on another filter, the first one (filter name) remains in edit mode. :o If I do the same thing with playlists, the click on the 2nd playlist takes the first one out of edit mode which is the expected behavior. If I go from a filter already in edit mode and then click on a playlist, the filter name is taken out of edit mode (good).
