Author Topic: GUI changes for v3.0  (Read 1402958 times)
this has fixes for most of the above issues:
http://www.mediafire.com/download/68ia4i13dy6oa0o/MusicBeeDemo.zip
  • MB Version: 3.6.9255 P
version 3.0.5777.39487
If using Artwork field in Track Detail configuration when using grouping header:
  • when first opened blank Artwork overlaid on grouping header
  • change to another tab and back and panel displays correctly
  • change sorting and artwork from a different album is overlaid on grouping header
  • again, change to another tab & back, panel displays correctly.
i can reproduce clicking on title and the # field disappearing and will fix that but i have no idea how you managed to get multiple # fields in there.
I try to add them from the "Set Displayed Fields" pop-up, and then I restart MB. And then I can't get rid of them. (edit: Actually, I hacked the settings file to get rid of them.)
GIF: http://i.imgur.com/B8DGZEo.gif
Album Artwork appears to still be cut off if the tracks continue beyond the bottom of the artwork.
Last Edit: October 27, 2015, 05:19:00 AM by psychoadept
Is it intentional that when you do a CTRL+A, all the empty space is selected, too?
can you post a screenshot so i can measure things
Alumni
i have sent you a PM with a debug version
Ok, I repeated the steps and here's what the log shows:
27/10/2015 19:46:10 - Object reference not set to an instance of an object.
27/10/2015 19:46:10 - Portable Device\Internal storage\Playlists\Rap New Favs.m3u,folder=o56,1,files=134
27/10/2015 19:46:10 - root=null
edit:
error log removed
Last Edit: October 27, 2015, 10:59:13 AM by Steven
can you send me your settings file (help/ support/ view settings) before you make any changes.
Its appears somehow the specified storage root folder for the device is no longer valid. You can set that in the device settings panel
Alumni
Sure, I just sent it.
I'm not sure why the storage folder would be invalid, what setting would you recommend?
By the way, I'm using MTP if that makes any difference.
Last Edit: October 27, 2015, 11:11:51 AM by Alumni
I don't have psychoadept's problems with the artwork cut-off and selection errors, and was testing to see if it might be caused by the position of the extra fields displayed - under artwork vs right of artwork.
Didn't get that far because I discovered this:
3.0 is displaying what I have set in 2.5 but the configuration panel is not updating.  I think these are the settings I was using when I first installed 3.0Demo.
This is the settings that are currently in 2.5:
coffeecup
Hi have been using version 3 without big problems untill today when musicbee threw out this error:
MusicBee v3.0.5777.39487 (Win10.0), 27 Oct 2015 11:10:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=qLYbYSeDEbqKh2v9raGNApeXx1NkTr8ooIrznlgEHg3k=..ctor(#=q7lWIb6XjdRGyEyzNAg_48KhGHpW3RjoJ1Jp1fMDun8E= #=qYCTft10K2VnrdJVq600OLQ==)
   at MusicBee.MusicBeeMain.#=qxdxhdrxdow9r4bTgM5ABsmwkbfKIH3YbKz8h4mjt0$w=..ctor()
   at MusicBee.MusicBeeMain.#=qRdB_3jDaprFFmDpXiF38qA==(#=qUXROS4DTh_lxBdqMH4U3sfuE499eqtx74p_OfteYcD4= #=qleFaDvuQ$DAq$6e2ChwNI8AGKm3pjYrZ1cQNkVY5X5s=, Boolean #=qQfxirtmdinwksgcrdW77gUyOx5fUzbfgN5XA3jt2$4w=, #=qA9fxmY9To8g6X8RQ2PyqdA== #=qYncjL7vBWQuo78g6jvBOVQ==, #=qZW7cF5qbvh9CCD8vA11q9bo3I1DKLPEcuQbC5baY2hE= #=qxvEd4BfLsgzM8LH3BBQAIbbkzcL$X6g66RTFytAEltU=, #=qNgKaJJgxQakZ8gs0NiZQKPQvdsZF8Ot5jCmLqM5kg2w= #=qU3zz562Mjbv6l2GpzB0lWw==, #=qMg6s4rbQbrWHmd0tMHUTXhA7S3Garug1V8_vG7Le2Hc=[] #=qGDd3KIIsmPMi1VNbl2rZm96FoGy47VUUaJ2697GcHRU=, Boolean #=qWXotc4hz8Me7aztIDGFQbmvdWvcXes6rlXBWIAWUYNw=)
   at MusicBee.MusicBeeMain..ctor()
   at MusicBee.MusicBeeApplication.#=qEV4ZXBvJnMC98TRYi3pDxw==(String[] #=qIq26FLaECM9oETNoVS02VA==)
I tried going back to earlier update but still got error.
i expect the main panel is being displayed using a custom view and you are editing the default Album & Tracks layout
please PM me a link to your settings file: help/ support/ View Settigs or (MusicBee3DemoSettings.ini in the AppData folder if you cant start MB
Alumni
A very strange error I noticed recently - can anyone else confirm? When analyzing volume and applying replaygain tags, MusicBee has been intermittently skipping tracks seemingly at random.
Although it says "operation completed successfully", checking the files with a tag inspector reveals that some tracks are missing the replaygain tags. The errorlog doesn't contain any entries for this, and I haven't yet figured out a pattern.
Still shot:
GIF: http://i.imgur.com/tOqZ6mF.gif
On my screen I could see the missing piece of the artwork flicker for second when I refreshed, but the FPS of the GIF is probably too low.
Last Edit: October 27, 2015, 04:28:17 PM by psychoadept
Alumni
@Steven
Thanks for the suggestion, I managed to get my playlists syncing by changing the path from "Playlists\" to "Portable Device\Internal Storage\Playlists". I assumed the device settings would automatically detect the correct path, but problem solved anyway.
