Yes I can switch using the dropdown menu, but not by clicking on the header panel/selector button (which functions fine in the main panel). So when I click on the selector button area in Now Playing nothing happens, but the menu button works fine.
you have lost me.
Firstly does the last update address the issue?
And if not then what do you mean by "Yes I can switch using the dropdown menu, but not by clicking on the header panel/selector button". How do you invoke the drop down menu?
Ok, I'll try using some pics to make this more clear. In the Panel Config settings there are 2 options:
1. ticked elements are displayed as tabs
2. ticked elements are stacked and viewable by clicking a selector button
With option 1 selected, multiple selectable tabs are displayed. Hovering over any selected tab displays a downward icon. Then clicking on the selected tab displays the Customize Panel option. *Note: although the downward icon appears with any selected tab, the Customize Panel option is only available for Details and Lyrics.
This is all working fine:
Although right-clicking any tab other than Details or Lyrics results in this odd rectangle being displayed:
With option 2 selected, a header button is displayed showing the name of the selected element. Clicking on this button displays a dropdown menu where you can select different elements or views, plus search or customize panel. This is working fine in all areas. To the right of this button is a blank area which if left-clicked will display/cycle to the next element on the list. THIS FUNCTION ONLY WORKS IN THE MAIN AREA, AND NOT IN THE NOW PLAYING PANEL:
EDIT: I forgot to add that the last update did not address this issue.
