Author Topic: GUI changes for v3.0  (Read 1253858 times)
I'm sorry, the topic is huge, but the function of searching duplicate is working? I say this because when I tried the version 3 never gets results, while version 2 always gives the expected result.
are you refering to the "Remove Duplicates" function or something else?
Yes, remove duplicates.
its working fine for me. Are you able to record a GIF file showing me what you are doing or even a screenshot showing the context menu open with the playlist visible might help
Havokdan
Same Settings
2.5:
https://i.imgur.com/ItwgZ4l.png
3:
https://i.imgur.com/6qH9Koi.png
In v3 never get any result, I even duplicate files to generate results. If you get results, is it a problem with the language that I am using?
RTesla
Guys, how are you getting the artist image that fills the entire left hand panel?!
Can't figure it out!
- fixes and changes for the items stated as fixed above
i think in v2.5 if you only have one file selected then MB selects all files. Its possible v3 doesnt do that but i will check tomorrow.
Just select all files in the panel using Ctrl-A and then open the duplicates manager.
edit:
confirmed - i will change the behavior for v3 with this function for the next update
Last Edit: March 18, 2016, 11:46:53 PM by Steven
brx
I've found 2 bugs:
1) Right click on Now Playing tab, right sidebar, change style. http://giphy.com/gifs/3osxY7K4Zx08B1qZXy/tile
2) Something strange happens when changing styles of the now playing playlist. http://giphy.com/gifs/l2R03Wad5DpExhOgg/tile
the first is fixed for the next update
for the 2nd i cant reproduce. Firstly could you try using the very latest version (yours is 2 days old) just in case it was already fixed, and if not then send me your settings (help/ support/ view settings)
It's ok now (v3.0.5921), Steven, thanks! :)
user73
i been updating these patches  of MB3 for long time as this post is getting longer n longer but problem i mentioned in my earlier post of Track information panel height not getting adjusted.....
so just trying to remind @Steven...though with so many users and so many requests ,i can understand it is possible to forget.and im also not in any kind of hurry.
its Just a reminder.
and another question, are we getting random skin option in next update like we had in MB2?
The bugs I reported are all fixed. Thanks!
But there's still an issue of width adjustment with centered text tabs. The tab header of some nodes gets truncated or not depending on the header length of the previously selected node. This happens with now playing node and most services nodes. For instance select music explorer node and then now playing node, then it's working fine. But select inbox node then now playing node, this time it displays "NOW...". This happens regardless of pinned state (with or without icons).
sleepless
You mean switching between tabs? I haven't noticed any problems there:
http://postimg.org/image/6oe8dnd19/
Although I have noticed some of that behavior when creating the tabs initially.
No, when selecting different nodes in a tab.
Artist picture element could be much more useful if it had the same context menu commands as compact player (next picture, paste/save artist picture, ban picture). Also consider adding "Keep aspect ratio" (tickable) option that would show original picture without cropping regardless of the configured shape of the artist picture element.
Related to this, I noticed double clicking compact player no longer pops up the full image of artist picture. Can you add that too?
+1, especially the first part.
user73
Plz check queue system..Its really messed up after last update.It don't shows count number like before and neither queue works the way it should be.
i have no idea what you are referring to
user73
Sorry steven...
at my side auto DJ option was turned on..as i never used it before so i thought queue system was messed up because of update...and after i turned off its all fine.Just like before..
