Author Topic: GUI changes for v3.0  (Read 1418294 times)
Alumni
make sure the 1st field in the sort is Year or Year (yyyy) and set the Sort order to descending
Right, but I was thinking of ordering decades in the opposite direction, so music from 2015 appears at the top of the library.
what i said should do that - did you try it?
Alumni
Oh yeah that does work if grouped by Year (yyyy), it's just that I was hoping to stick with Decade for grouping.
Edit: Actually I can probably get used to it this way. The only thing that's confusing for me is the jumpbar, it still reads from oldest to newest (left to right), with my current sorting preference not reflecting that same layout.
Last Edit: March 11, 2016, 07:09:39 PM by Alumni
i will enhance it so Decade grouping is also included when sorting year in descending order
This has come up in the past but seems worth mentioning again: if you create a new playlist by clicking on a playlist folder, the playlist is added to that folder (which seems desirable).  However, if you duplicate a playlist already in a playlist folder, it is created at the very bottom of the playlists list, not in the folder (which seems not so desirable).
Last Edit: March 11, 2016, 09:36:57 PM by psychoadept
user73
hi
i would like to report another issue.
from below screenshot u can see. rating of playing track is 5 ,
while the actual rating is 1star.
it happens to all the tracks.means whatever track i play it will show playing track with 5stars.
http://i.imgur.com/dXqeGMa.jpg
earlier i thought it has to do with tundra series skin and posted in tundra post but musicbee leever said it has something to do with my dpi settings.so i tried with other skins but problem is still there.then i changed my custom settings to default 100% settings but this issue remains there.then i try with 125% and 150 dpi settings ..but issue is still there.I also try changing musicbee fonts to default font settings but problem is still there.but this issue is only with v3 ..with MBv2 it is fine...
I wonder why im only one facing this issue.
@user73, it might be a skin issue. Can you post a screenshot using the MusicBee3 skin
- fixes and changes for the items stated as fixed above
  • MB Version: 3.6.9318P
I didn't say it was DPI settings - I said it might be DPI settings (http://getmusicbee.com/forum/index.php?topic=7186.msg106664#msg106664) as the top border is also not showing correctly in your screenshot
user73
sorry bee liever i didn't quoted your exact words earlier and neither i read carefully that u said MIGHT ...i just tried to follow your advice...Now i  think i might have offended u by mentioning your name but i didn't intend to do so.
 ..and Yes you said it MIGHT be dpi settings..
.im very busy man..so just replied in a hurry.
hope i be careful next time..though im replying still in a hurry.  :P
Noticed sidebar player for now playing tab doesn't display duration.
Not offended.  Not even a little bit :)
was making sure Steven knew that I'd checked it out and couldn't find a fault in the skin
Please adjust minimum column size for Play Count.  When I use "Auto Size All Columns" on my main library layout, I get this:
which is kind of silly.  :)  (No, there are no other digits.)
Alumni
Awesome, thanks! Would it be possible to swap around the jumpbar depending on sorting order (only for years/decades)?
