Author Topic: GUI changes for v3.0  (Read 1403869 times)
Holding Shift to toggle Stop in the player controls is working fine, but the Stop symbol doesn't show up, at least in the sidebar player.
When hovering mouse over a playlist, the tooltip from the "description" of the playlist no longer displays as it did in v2.5.
thats added for the next update
Using the new option Icon + Text for pinned tabs.
It gives a minimal width (as per Steven's description) but is the option title not going to lead to user confusion as it doesn't actually give an icon with text on the tab?
i guess your default tab setting is text only? For pinning it now always includes the icon. I might get rid of the text-only tab setting and always show an icon
Got this error while configuring an ipod to synchronize with a single playlist.  First time I've tried setting up the ipod in MB.  When I tried to go back and duplicate the error I couldn't but thought I'd post the message should you find it helpful.
thats probably fixed for the next update (couldnt reproduce it but can see what it probably is)
- fixes and changes for the items stated as fixed above
i cant reproduce this. Keep in mind the shift key only takes effect if the mouse is over the player bar. Thats to stop unwanted flashing of the button everytime the shift key is pressed
rurutia10
If you hold the volume slider then let go of the mouse button on a tab, it'll open that tab. (a little annoyance sometimes..)
RTesla
With that latest patch, Pinned icon + text tabs working great now. Never noticed if you click on the tab it will open the left sidebar, that's a great addition to have.
I don't know what you're calling these, nor do I recall reading anything about adding them, but this is -GREAT!!-  I really missed having the ability to instantly know if I was looking at selected track info and lyrics or playing track info and lyrics.  Thanks for implementing this Steven.  And thanks to whoever suggested it.
Last Edit: February 28, 2016, 08:43:08 PM by phred
carloscs
Problem in Rip CD dialog:
that should have been fixed the other day. You are not using the most recent version
Was using a patch to the latest beta version at the time... Trying now with the just last beta (v: 3.0.5895):
It seems I was optimist: it happens all the time, not after a few rips. After ripping:
- a message about analyzing volume appears
- the cd ejects
- album data is cleared (album artist, etc)
- "CD has been removed" message appears on track list
- track list isn't cleared
Also:
Open Rip CD dialog, click on track list -> error appears:
MusicBee v3.0.5895.37007 (Win10.0), 28 fev 2016 20:00:
   at #=qi$zi2gN5yhuOAdxQKHd5yeCRdJjhTZitMaZYDY11CRM=.#=q5Cc6rOIOqmhf6E7o1yLVBv1RG_nBaHyolo82NOlyXKc=(Object #=qAeBQgyGxoHjly2CBk30lgg==, MouseEventArgs #=qCHFKEZMIHmqQfE9nPxlrJQ==)
   at #=qCBOUNiPC0oh1bLzYn4sKblfkyTE0pILYfq$vLehvHD4=.#=qCuj6GdCcWeN2a6JaNxWg9winc0Xkr4Ci_$lLnki$H9k=(MouseEventArgs #=q_6_GtwR7ZMw0t4bRd8UIoQ==)
   at #=qCBOUNiPC0oh1bLzYn4sKblfkyTE0pILYfq$vLehvHD4=.#=q_UHNj9DmVpAIriCM_er1jA==.OnMouseClick(MouseEventArgs #=qXcXcNl5LmnIbC_vzrQe8Iw==)
   at #=qMjaHHEO4hl4D6r8AMBBxZDjiOmLk1zoS$6AuyzDs0B4=.WndProc(Message& #=qwVDro9yF69e1IIJplZLMCw==)
- the cd ejects
Also:
both are fixed for the next update
carloscs
Another bug:
- edit a track/album and do a "Search Internet" for a picture: if a picture isn't found the not found dialog appears twice.
IIRC, it hapens also on the Rip CD dialog, but probably it's the same code path.
in the Now Playing Tab, I can't view neither Lyrics nor Artist Bio on the Main Panel Right Side unless the Right Sidebar is open.
Related to this bug, you only see scrollbar slider without the element when showing and hiding right sidebar.
It works if the track is playing, but if it's paused and you want to stop/release it, the button doesn't change.
that wasnt implemented in any panel but i have done so for the next update
DarkerthanDreams
Hey again all, still loving all the updates.
One glitch though, don't know if this is on my side only, but in the Now Playing Tab, I can't view neither Lyrics nor Artist Bio on the Main Panel Right Side unless the Right Sidebar is open. i.e:
No Lyrics
Lyrics Viewable
what skin is this?
