Author Topic: GUI changes for v3.0  (Read 1254534 times)
Folder selection box is not drawn for auto-sweep settings.
A small bug with the expanded menu, when grouped by album artist;
Select a track from an album, then click on another album in the same grouping, a track is already highlighted in the same position as before. For example if you select Track 1 on Album A and then switch to Album B, Track 1 will still be highlighted without user input.
Last Edit: February 20, 2016, 05:32:16 PM by Steven
- fixes for the items stated as fixed above
SoftwareSamurai
With MB2, in the Navigator panel when looking at folders under a drive letter under Computer, you could hit a letter on the keyboard and it would jump the highlight to the next folder starting with that letter. This doesn't happen in MB3. Intentional? If not, may I suggest supporting a quick-search whereby I can type the first few letters of a folder's name in order to highlight it?
i have added support for that in the next update
Ah, wonderful! Thanks!
- Folder selection box is now drawn but the dialog is misaligned.
- "highlight playing track in the main panel" with "select track" option is not working again.
I can't seem to edit Genre in the main panel.  Is this working for anyone else?
Which view?
Track details, Search Results node.  All other columns are fine.
Working fine for me. Are you sure it's Genre not Genres?
Ah, that's it.  Not sure why I did that.  But I'd still expect you could edit it in the main panel.
carloscs
Problem in Rip CD dialog:
I've been ripping more than a dozen cds and after a while a problem appeared:
After ripping and after the cd auto ejects, the "CD has been removed" message appears but the track list isn't cleared (the first few times the track list cleared). Clicking on one track on the track list results in this error:
MusicBee v3.0.5891.39020 (Win10.0), 21 fev 2016 2:49:
   at #=q9MCJ7rNN_iuyMTfZcXnOjasimUwC7kSepqjZAXp3pqA=.#=qVAhnq0Cv9xDLU1mdhYDMAZvqVE6nUej12cjNS_I6gpE=(Object #=qln04dC1PIjLfIQqn$bTSPg==, MouseEventArgs #=qXB48Vd6heAyBtF_hIXAwWg==)
   at #=q6YPAorwUm0W9KdigNpe5U3_VR6BnTvONhe9BACHaDM4=.#=q7apx9OA8KPD6kIIE0rTxHbE1Ixh$dTYZzJ$z7HAFuXw=(MouseEventArgs #=q5_$8niPrGqG$2LUPm2WPTQ==)
   at #=q6YPAorwUm0W9KdigNpe5U3_VR6BnTvONhe9BACHaDM4=.#=qsTIACghd76uZAW4BNJ7agQ==.OnMouseClick(MouseEventArgs #=qs0xg0vl5NaBQoKzBiob4kA==)
   at #=qL4a3L7Ig0srCaMkfdIHw_F6AAdKAfu_joXqlWYRAWQc=.WndProc(Message& #=qCjyjsdOVFJC_bNQ_vBLjOQ==)
In 2.x, when you do a search and then filter from the search results (for instance, with a middle click), using the back arrow would return to the previous search results.  In other words, it treated each search or filter as a separate "location".  In 3.0, it goes back to the node you were in before the original search, treating all search results as one location.  Could we have the 2.x behavior back, please?
that should have been fixed the other day. You are not using the most recent version
I havent changed it and its working fine for me. Perhaps post a screenshot so i can see your configuration or send me your settings file
can you post a screenshot.
Sorry. Looks like I was mistaken about it with a different node open from playing tracks list.
