Author Topic: GUI changes for v3.0  (Read 1406233 times)
Sofocl
Enable Now playing dar > Artist biography or Theatre Mode;
Result: You can not change the image.
Enable Albom Cover > Selected Trecks;
Sorry for my bad English.
Sofocl
"Auto-Tag by Album" do not apply to cue files.
  • MB Version: 3.6.9255 P
spacing between new left sidebar elements (Now Playing and Music Explorer) is not consistent with other items.
9 pixels with all other items
16 pixels between last item and Now Playing
then 11 pixels to Music Explorer
lizzy
With the latest update,  in "NP" with playlist selected, I cannot find any sorting options.  It seems like it automatically sorts to shuffeled tracs when shuffeled is enabled.  Here's a screen
https://www.dropbox.com/s/uw74ks0xhhlky3g/mb3-sort.jpg?dl=0
the now playing list whether its in the main panel or in the right sidebar reflects the order tracks have been added for playback.
Shuffle doesnt affect the display order. I am guessing you used "Play Library Shuffled" or an auto-playlist to create the now playing list.
As with when displayed in the right sidebar, the display order can be changed by clicking a column header but that shouldnt affect the playback order
lizzy
Yes, added entire library to NP with "Play Library Shuffled". In previous versions there was a sort option when right clicking the column header (NP main panel), but that option is gone.
If you have the Spectrum visualizer or the Wavebar located above e.g. the Lyrics panel in the right sidebar, you can not resize the Lyrics panel anymore.
Tools, Tagging Tools, Search & Replace   no Replace
thats an issue specific to windows 10 and fixed for the next update
Error thrown when having Thumbnail browser in the Left main panel, set to 'Album', selecting an album, and then pressing any letter:
MusicBee v3.0.5850.38692 (Win10.0), 8 jan 2016 19:48:
   at #=qCtJfqUQRlGt6OuCfkzfzdpslt8YXVK9ExtX6IYZsufk=.#=qBUz8dJEasMrez4p9gWsHZOHZ8oIKLzVXKhUiO1rZqmo=.OnKeyPress(KeyPressEventArgs #=qRanqdhT$0UKL_1aJfOvM2w==)
   at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   at System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
   at System.Windows.Forms.Control.WmKeyChar(Message& m)
   at #=q7W7Wy8Cp3hgS5QmI$g29rbHCwGPaswGKPzd4_NjridY=.WndProc(Message& #=qC7Cb2wkR36nef09$3mwxLQ==)
i cant reproduce any issue. Would you mind sending me your settings file
Under Set retrieval filter, there is a duplicate entry for Folder.jpg.
Tags(1) > artwork storage
Under Set retrieval filter, there is a duplicate entry for Folder.jpg. It came into existence after selecting the first entry. When I select both the normal and the duplicate entry and save, it doesn't keep this setting, only one entry turns out to be selected after reopening the retrieval filter. The dupe does not show in the Album cover search rules window either.
the 2nd is fixed for the next update. For the first I cant reproduce any issues so could you send me your settings file (help/ support/ view settings)
it wont update the cuesheet if thats what you mean
- fixes for the items stated as fixed
Sofocl
Thank you! The latest patch fixed the first problem also.
MB applies the changes to media files (flac, ape... etc) but does not change the cue file.
cue > Auto-Tag by Album > Applay tags;
The result; In "playing tracks" and "Library" will show MB change, open the "Edit cuesheet" and make sure the changes are not applied.
