Author Topic: GUI changes for v3.0  (Read 1405042 times)
hamma
How can i completely disable "left main panel", or did i oversee an option?
I got this error while trying to adjust the volume tonight (I clicked on the volume icon in the right sidebar):
MusicBee v3.0.5835.39399 (Win10.0), 23 Dec 2015 21:29:
   at MusicBee.MusicBeeMain.#=qeDbEHfJU35ocFWM22XKcrw==.#=qdclmy2ZrZISTSXWAe2ZyBVKasb3a6QTDwOBIc4jSWqE=.#=qSM68U$4Sbq4RNA9YAXZYmYfodLjAD3gRnHAf3$tNSqA=()
   at #=qTVBHIq_kjSqIk8IocIXHQes0I00abSaJR8tiHreijCxb2AOxvPGMJ_i8eObanVEB.#=qPx2KE9EQGq0S40SqeUJuvjaatAgjrQtbdw3_dBDW1o4=()
   at #=qDl69Jkej10IpEMNSWyKHCaVzV_WFoyaEU$IgvucJrEA=.#=q_j9aTq78d0WZE66uWmGqhUZwbQm$okn2cUwPne5uIEs=.Invoke()
   at #=qDl69Jkej10IpEMNSWyKHCaVzV_WFoyaEU$IgvucJrEA=.#=qsoNR$H6X4nno3zC2gQ3qbQ==(Boolean #=q5rOF1rIdggArWWFcbofxCQ==)
   at #=qTVBHIq_kjSqIk8IocIXHQes0I00abSaJR8tiHreijCxb2AOxvPGMJ_i8eObanVEB.#=qqaioUxyz$37uWDa9rA1dNyg$NaJAt6rF_o$WuFY$yn4=(Object #=q0Aa4EeDAjRaAxm8O6T9s4g==, FormClosedEventArgs #=qXlcWtXUV4aDTAN$sHAQ$Mg==)
   at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
   at System.Windows.Forms.Form.WmClose(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=qET2eowkYz03aBblrDzF$62HYNn1dP6XjxPnxqY5JdSs=.WndProc(Message& #=qG6pP1Hj2zuF3N9ntxah5JA==)
I'm running the plugin that links the volume to the windows volume control, for what it's worth.  Also the text display of the volume level got visually corrupted.  If I use the keyboard controls to adjust the volume, it shows the correct number, though.
Last Edit: December 24, 2015, 05:25:59 AM by psychoadept
Alumni
In the panels configuration window - you can either disable/move elements docked in the left main panel, or you can hide it from view under "overrides for the current tab".
hamma
Where do i find "panels configuration window"?
When i go to preferences - layout (1), i can only choose the size of the thumbnails and hide it for playlists.
I finally found it, thanks @Alumni
Last Edit: December 24, 2015, 07:44:35 AM by hamma
click the Panel Layout icon to the left of the search box
Could you confirm whether you have the main player panel displayed (if not that will probably be the reason which of course i will fix)
if thats not the case, it might be relevant as to which skin you are using, and if its one in development can you send it to me (if its the melon remix 3 i already have it).
Last Edit: December 24, 2015, 08:22:16 AM by Steven
EffenBlue
When I try to paste artwork to a file I get this:
No, the main player panel is not displayed.  And yes, using the Mellon skin.
fix for the volume issue and the paste artwork issue (for anyone using the new narrow scrollbars feature):
Last Edit: December 24, 2015, 06:03:00 PM by Steven
cartman005
I'm getting the following error when I open a new tab.
MusicBee v3.0.5836.30373 (Win10.0), 24 Dec 2015 12:10:
System.ObjectDisposedException: Cannot access a disposed object.
Object name: '#=qNUUFhhBiViLNx5bVy1Kytg=='.
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at #=qFKW_d_wVi3ZpjxCEcB2Zq48Cm9OFNYjz0QRdR_Fd6b4=.WndProc(Message& #=qMzWB776BHbVDTTwsWrsIYQ==)
h0m3r
confirm the fix :)
great! big thanks for your work! ;)
that should be fixed now:
cartman005
It works now. I think I am missing something with the Playlist Manager. Is it supposed to show up blank like this?
its another bug with your settings. It should be fixed now:
