Author Topic: GUI changes for v3.0  (Read 1398711 times)
STEPS:
EDIT > PREFERENCES > LIBRARY > PRESS CHOOSE FOLDERS BUTTON
I get a crossed lines blank square and the error message (using default MusicBee 3 skin). If I use the MusicBee Classic skin, for example, the error doesn't happen.
for some reason MB cant load the tick box image. I notice you are using Vista so its problem some windows bug.
First off, could you delete musicbee3.xml and make sure musicbee3.xmlc is in the folder (its included in the download) and see if that makes any difference.
Also are there new errors in the error log every time you launch MB using the MusicBee3 skin?
Last Edit: December 11, 2015, 05:32:56 PM by Steven
I downvoted a track to 4 stars and it still shows a virtual tag score of 100. I just went on to see what happens if i downvote multiple tracks, result: album rating and the visual virtual tag value changes sporadically. And yes, auto-calculation is activated.
what is the forumula for the virtual tag?
Boile
Hi Steven,
i have another one issue!
In the lyric window if you right click on a lyric to edit--> EDIT DISPLAYED LYRIC, than again right click- in the sub-menu are missing lines and you cant edit!
3.4.7586
scartez
STEPS:
Thanks for your reply.
musicBee3.xml was already deleted. Only musicbee3.xmlc was in the folder. These are the errors in the error log when I launch MB with the MusicBee3 skin:
11/12/2015 16:26:42 - Unable to load element: -663114390 - Parâmetro inválido.
11/12/2015 16:26:42 - Unable to load element: 1513069963 - Parâmetro inválido.
11/12/2015 16:26:42 - Unable to load element: -766100460 - Parâmetro inválido.
Hope you can find what is going on.
Cheers!
i have sent you a PM with a debug version. Let me know if it works
Hi Steven,
when you go into edit mode, only "Cancel Edit" and "Save Lyrics" are available as options
If thats what you see then thats as intended
fixed for most of the above
http://www.mediafire.com/download/yg2iu46j3binune/MusicBeeDemo.zip
scartez
Debug version works perfectly. Thank you. Should I keep it?
Boile
the column issue is now corrected, but without copy and paste is difficult to edit something!
Greetings
3.4.7586
When clicking on the Podcast Group Title (for lack of a better description) I'm getting this error.  MB doesn't close, crash, or otherwise malfunction.  Clicking on an individual episode plays the episode as expected.
MusicBee v3.0.5823.33748 (Win6.1), 11 Dec 2015 20:22:
   at #=qvkpov$B6If92ngxs__MdeRe41j3aVAaAREQWOpx87pE=.#=q8E_V$VbtbMzSo8IBl_PMtx1t6mcGWj65oaGw2wRHBrU=(#=qpT3Gz8T1fisl3NLgf3XZOHLOD49LrUOTLw9kEEIIW7c= #=qj9P6oVXlk4ArGclii$fDYQ==, #=qMgUmZNdzbfmnalR5SswTTA==[] #=qURTG64cfRZ3CwwobZxJG1g==)
   at #=qvkpov$B6If92ngxs__MdeRe41j3aVAaAREQWOpx87pE=.#=qZkSM_1AwT$vQD7MQd4gxxw==(#=qpT3Gz8T1fisl3NLgf3XZOHLOD49LrUOTLw9kEEIIW7c= #=qiHajpSKdQdwCG_NAHc6bcw==)
   at #=qvkpov$B6If92ngxs__MdeRe41j3aVAaAREQWOpx87pE=.#=qo0x2il92ArjcdJp18dHUUQ==(#=qpT3Gz8T1fisl3NLgf3XZOHLOD49LrUOTLw9kEEIIW7c= #=qvGc$QYYptD15D0IF2xm55Q==)
   at #=qsfzi8D0UgSOC9r9wQgkyda_bEYXblko$8KCDinzRiLw=.#=qJoC$GSVmVs7zxD$ZBPx$$A==(Boolean #=qfIVf3J3e5RAUT5tf6Bkshg==, List`1 #=q4FGASYdtm$Y4DPkgm3uX9Q==)
   at #=qsfzi8D0UgSOC9r9wQgkyda_bEYXblko$8KCDinzRiLw=.#=q2Qu7Vebq5M50tOXFVM9e7IItm5GU4woOL_mcFamS1Do=(List`1 #=q4EAMNMZmSpWxs214U28gZw==)
   at MusicBee.MusicBeeMain.#=qaRtz$oDDuJV_D9eTV4_zIYTUZ2yuX3jxVIJo_PCkjxY=(#=q77gNmgx1BpaCjwkpqO_YvA9Knmc9EnDsCTyspoUi164= #=qgjM8sij5_yVUZXoQmTRccw==)
   at MusicBee.MusicBeeMain.#=qdh2k9xUEG0d69vDDo1SM4A==.#=qBRPgGORiXJurgO41Y7SwEA2kahgDJKL9UpCbyRkOVlw=(Object #=qGnL8tC0ub3jP1akEczAUDg==, #=qf5lfIedH2ta1uD9X7yxxmLgZuU$W51A2tXiuQcpfT8_F5RooUeDIDpXaxHU76QtQVgIsA23r7Wjnm4TLdBJTzA== #=q2MXJAfixtm8zgLRIYES9$g==)
   at #=qgo6PwyzkLp$E7mlole0dX3fjviHdWMwcQkTAcdvjWMo=.#=qBJlkXCmM9F2ClXGdgDq7tQPIf8cl_ImlTpTLJVSHmaQ=(#=qf5lfIedH2ta1uD9X7yxxmLgZuU$W51A2tXiuQcpfT8_F5RooUeDIDpXaxHU76QtQVgIsA23r7Wjnm4TLdBJTzA== #=q8_MB2FBFoX9ZuDDfmA1_YA==)
   at MusicBee.MusicBeeMain.#=qm4IaWmAdLID2uh_8Sy3_dxdQR_dQl2eiuV4KifoudaM=.#=qBJlkXCmM9F2ClXGdgDq7tQPIf8cl_ImlTpTLJVSHmaQ=(#=qf5lfIedH2ta1uD9X7yxxmLgZuU$W51A2tXiuQcpfT8_F5RooUeDIDpXaxHU76QtQVgIsA23r7Wjnm4TLdBJTzA== #=qr5jB0TLZ1DylkysLxW0WKA==)
   at #=qgo6PwyzkLp$E7mlole0dX3fjviHdWMwcQkTAcdvjWMo=.#=qFPpKwYVTcp4R00B9U5A4PA==.#=qtGI23rBaXtRw4M$hWag$ggl_cLOjTmO5rDQG1WYAzxw=(Int32 #=qO64G_KdWE5a6oupxsTWtLQ==, Boolean #=qeE3JMSa3ZHJw7SCqFFr0bA==, Boolean #=qTyqBI$pvfyPVslIZMNuZDWVL5uGGgjlWgsrr6$c1kz0=)
   at #=qgo6PwyzkLp$E7mlole0dX3fjviHdWMwcQkTAcdvjWMo=.#=qFPpKwYVTcp4R00B9U5A4PA==.#=qty5FLuYHXV4f0pYJ$mAPae9AIqSQqALBUXeLzMLA$vFbBC_RUy4s25I0VkifD23d(Int32 #=qlS7g$YLkrXYieEPK34cZzQ==)
   at #=qgo6PwyzkLp$E7mlole0dX3fjviHdWMwcQkTAcdvjWMo=.#=qFPpKwYVTcp4R00B9U5A4PA==.OnMouseDown(MouseEventArgs #=qbiC8qMGChVta8NOLLo0iVQ==)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at #=qOZ5I_6Ni$2x5rGP1n2f$S4$GgKQlka7TKHq3D4ec$VM=.WndProc(Message& #=qLZ8tpLuD_69bFi$felttnw==)
its fixed for the next update. In the interim, just set the track info/ lyrics panel to "Playing" rather than "Selected Tracks"
Alumni
introduces a new Play Now action (in the Now Playing preferences) to play the entire album only for the track you double click on
Thanks, I really appreciate this addition.
I think 'Now Playing' could benefit from another option that allows for 'contextual' behavior. For instance, when I double click an album in artwork view I would like it to play only those album's tracks, but at the same time when I double click a song in track view, I would expect it to keep playing the rest of the playlist.
Last Edit: December 12, 2015, 02:48:58 PM by Alumni
- Send to Auto-DJ duplicates the starting track (https://i.imgur.com/jNJ70mY.png) (started via toolbar command while selected track is already playing)
- strange behavior with Auto-DJ: if you try to skip a track, it will play the starting track again, after that if you skip again, it will play the next song in the usual order, and so on. means: per every second skip it will play the starting song again and again.
i cant reproduce either of these. Can you send me your settings file (help/ support/ view settings)
(I can reproduce the slowness/ locking up when the initial list is large and thats fixed for the next update)
- error in preferences > Layout (2) > compact player > select configure panel
i cant reproduce this. I might be able to reproduce with your settings but if not i will need the error dump when it happens
- assigning star ratings for tracks in artwork view using the mouse (also with half star ratings activated) isn't fluid, needs px adjustments
- refreshing of album rating not fixed yet (https://i.imgur.com/9GPPYWQ.png), it refreshes, but shows previous ratings sporadically
both of these sound like issues i fixed yesterday. Are you using the version from yesterday?
Last Edit: December 12, 2015, 03:45:21 PM by Steven
the above two and compact player settings dialog are fixed for the next update.
For the weird track skip behavior, i would say the reason is because you have playback follows cursor. Lets say you start with double click track X which is now highlighted. That song plays and then when finished goes to the next track. When that track finishes, if you still have track X highlighted MB will jump back to that track and when finished go to the 3rd track, then jump back to the highlighted track
I still need to do more comparison with v2.5 so there still might be some bugs but so far its doing what playback follows cursor should. Did you really want that setting?
