Author Topic: GUI changes for v3.0  (Read 1254035 times)
I'm trying to update the artwork for all my albums and the artwork downloader appears to be ignoring my settings for artwork storage. I've unchecked embed artwork in file and have set it to save it all artwork in my pictures folder. However when I hit save all in the artwork downloader it begins embedding the artwork in all music files which is precisely what I do not want to do.
i am not able to reproduce this, however it is possible it could be related to a fix i am making for phred, so could you try this version
http://www.mediafire.com/download/68ia4i13dy6oa0o/MusicBeeDemo.zip
Also note that if a file already has artwork that is being replaced, MB will preserve the existing picture locations ie. if the file already has embeded artwork, the new picture will replace the embeded picture
Sofocl
1. Blinks "left main panel", and a little sluggish "Right sidebar";
2. Is not working change "Artwork"
3. "Now playing bar" comes up against invisible wall, and only moves down;
Sorry for my bad English.
Where are you thinking the distinction needs to be made? Do you mean for the sake of explaining things on the forum, or in the program itself?
Both actually.
I think at any place and location where it mentions, or refers to saving, copying, deleting, moving, backing-up etc, it would be good if it was clear if that references to the database file, or to the music library.
@Sofocl, for 2 the two pictures are in conflict - one is selected and one is the playing track which should work ok for the primary pictures of each. I doubt i will be able fix that
for 1 & 3, i would need your settings file
@bee-liever, your reported issues should be fixed now
Last Edit: October 16, 2015, 09:25:25 PM by Steven
Sofocl
I do not see any conflict ..
https://dropmefiles.com/KIwvT
Justin34
Getting the error below when I get the "Download Artwork" button under tools when I select all tracks from "Files with Missing Artwork". I'm trying to download the closest artwork match for all the albums I have and save the picture in the same folder. Embedding pictures in the music file is not an option for me.
MusicBee v3.0.5765.32543 (Win10.0), 17 Oct 2015 9:12:
System.ObjectDisposedException: Cannot access a disposed object.
Object name: '#=qszxcAQUK7T_MAdDifCC60Algaq56OiChrR9JK6$WmGZ6jZp28mdFaJONM831XGg9'.
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Form.CreateHandle()
   at System.Windows.Forms.Control.get_Handle()
   at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Control.Show()
   at MusicBee.MusicBeeApplication.#=qothIi3arIJg6cPgEtTzWsQ==.#=qgMswi$oiZM_pTV2zppEit4ac1nVLX_Uc$ZF9I4ebiUU=(List`1 #=qF8RNQ_DoNqpCKbbTseaRzg==)
   at MusicBee.MusicBeeApplication.#=qx8iFpWniZ7s12IkcPXwatw==.#=qyG9DF0t4352$tgxHYoMBJg==(ApplicationCommand #=qDV7Ew8ED7GrD_vYQzl5qOQ==, Object #=qtTLvAt3Y$tIINuCBccyP1A==, IList`1 #=qSRjxX_bfi75LXHd9XR3QEQ==)
   at #=qvHLerQvxYuTQm1OtrTALLBQLxnVPSDzD5t4xUR7Cz3c=.OnClick(EventArgs #=qmaHC_WDs8o9vWDOCMpEGyg==)
same instructions as before - unzip into the folder where MB is installed and run MusicBee3.exe
@Justin34, although i cant reproduce i have made a couple of changes that should correct the issue
@Sofocl , 1 & 3 should be fixed now. I probably wont address 2
@Bee-liever, your reported issues should be fixed
@phred, the CD ripping issue should be fixed.
This also addresses an issue when saving tags that are not stored in the music file so i recommend you update to this version
Last Edit: October 17, 2015, 04:23:42 PM by Steven
before i spend to much time on this i have made one fix for when a custom view is no longer available, it should now revert to the default configuration. As i dont have your custom views i cant be sure if thats whats going on. So try this and let me know if it works
Sofocl
It can be connected
In version 2 you can drag and drop Artwork;
Now it is impossible. This feature will return?
I updated, and still getting errors on both the first playlist in the folder, and on the inbox.  Do you need me to send custom views?
@psychoadept, this should fix the issue you are having
Yep, those two are okay now!
Justin34
Thanks that did the trick
EDIT: If I uncheck the "Preview and choose each picture before saving" option in the artwork downloader it begins processing the queue but no pictures are actually saved in the album directories.
